Up to 20% off select tools
Nikon D90 Rear Display Buttons Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
6
Past 7 Days:
36
Past 30 Days:
125
All Time:
3,691
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
With this guide you will be able to replace any of the buttons around the rear LCD screen. Buttons get worn and connections break. This guide will help you disassemble the camera so you can replace the buttons. Be careful not to strip the screws when disassembling the camera.
    1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: step 1, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: step 1, image 2 of 2
      • Locate the screws on both sides of the camera.
      • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
      • Be careful not to strip the screws.
      Ask FixBot
    2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: step 2, image 3 of 3
      • Use a plastic opening tool to separate the rear case from the camera.
      Ask FixBot
    3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: step 3, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
      • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
      Ask FixBot
    4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: step 4, image 1 of 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: step 4, image 2 of 2
      • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
      • Remove the ten 5.3 mm Phillips screws.
      • Remove the three 4.3 mm Phillips screws.
      Ask FixBot
    5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: step 5, image 3 of 3
      • Use a plastic opening tool to separate the LCD and metal plates from the casing.
      Ask FixBot
    6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 1 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 2 of 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: step 6, image 3 of 3
      • Use a plastic opening tool to separate the buttons from the casing.
      • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
      Ask FixBot
Author
with
jonothon cawley
354 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 36
Past 30 Days: 125
All Time: 3,691
