Up to 20% off select tools
Nikon D90 Flash Hinge Spring Replacement
Views: 5.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
124
All Time:
5,373
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The spring of the camera flash can sometimes wear out and needs to be replaced. This guide shows how to replace the spring within the hinge of the camera flash. Be careful not to strip any screws when disassembling the camera.
    1. Nikon D90 Flash Hinge Spring Replacement, Open the Flash: step 1, image 1 of 3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: step 1, image 2 of 3 Nikon D90 Flash Hinge Spring Replacement, Open the Flash: step 1, image 3 of 3
      • Use a plastic opening tool to lift up the flash.
      Ask FixBot
    2. Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: step 2, image 1 of 2 Nikon D90 Flash Hinge Spring Replacement, Flash Casing Screws: step 2, image 2 of 2
      • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
      • Be careful not to strip the screw heads.
      Ask FixBot
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: step 3, image 1 of 3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: step 3, image 2 of 3 Nikon D90 Flash Hinge Spring Replacement, Removing the Top Flash Casing: step 3, image 3 of 3
      • Use a plastic opening tool and carefully pry open the top casing of the flash.
      • Then, lift off the top casing of the flash.
      Ask FixBot
    1. Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: step 4, image 1 of 2 Nikon D90 Flash Hinge Spring Replacement, Loosening the Spring Screw: step 4, image 2 of 2
      • Using a PH00 screwdriver, loosen the 3.3 mm Phillips screw from the spring.
      Ask FixBot
    2. Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: step 5, image 1 of 2 Nikon D90 Flash Hinge Spring Replacement, Releasing the Spring: step 5, image 2 of 2
      • Use a plastic opening tool and carefully pry up the spring arm.
      • Doing this with release the pressure of the spring.
      Ask FixBot
    3. Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: step 6, image 1 of 2 Nikon D90 Flash Hinge Spring Replacement, Removing the Spring: step 6, image 2 of 2
      • Finish removing the screw holding the spring in place.
      • The spring can now be removed and replaced.
      Ask FixBot
Author
with
Matthew Grota
598 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
72 Guides authored
2 Guide Comments
These are great tutorials,
I was looking for one on how to fix the pop up flash not locking down,
It was bought second hand and dropped on the logo,
The front panel needed to be replaced,
Now for the Flash that is constantly up.
Any links? jjryzler@gmail.com
Ryad Arlan - Reply Share
My flash won't stay down. I think the piece that clips in to keep it closed may have broken. Is there a way to fix?
Linda Wick - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 124
All Time: 5,373
