Up to 20% off select tools
Nikon D90 Flash Bulb Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
39
Past 30 Days:
137
All Time:
8,785
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
With a few simple tools and parts, this guide will help you replace your broken or burnt out bulb on the Nikon D90 camera. Be careful not to strip the screws as you disassemble the camera. In addition, be careful not to break the bulb or cut yourself on a broken bulb while you are disassembling the camera.
    1. Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 1 of 3 Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 2 of 3 Nikon D90 Flash Bulb Replacement, Open the Flash: step 1, image 3 of 3
      • Use a plastic opening tool to lift up the flash.
      Ask FixBot
    2. Nikon D90 Flash Bulb Replacement, Flash Casing Screws: step 2, image 1 of 2 Nikon D90 Flash Bulb Replacement, Flash Casing Screws: step 2, image 2 of 2
      • Using a PH00 screwdriver, remove the two 5.3 mm Phillips screws from the flash casing.
      • Be careful not to strip the screw heads.
      Ask FixBot
    3. Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 1 of 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 2 of 3 Nikon D90 Flash Bulb Replacement, Removing the Top Flash Casing: step 3, image 3 of 3
      • Use a plastic opening tool and carefully pry open the top casing of the flash.
      • Then, lift off the top casing of the flash.
      Ask FixBot
    1. Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: step 4, image 1 of 2 Nikon D90 Flash Bulb Replacement, Removing the Bulb Tape: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Carefully unclip the bulb casing from the plastic casing using tweezers.
      • Remove the black and white tape on the bulb casing.
      • This tape is what holds the wires and bulb in place.
      Ask FixBot
    2. Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 1 of 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 2 of 3 Nikon D90 Flash Bulb Replacement, Removing the Bulb: step 5, image 3 of 3
      • Remove the rubber stopper on the left and right side of the bulb.
      • Separate the rubber stopper from the white and black tape.
      • The bulb can now be slid out and replaced.
      • Be careful not to break the bulb or cut yourself on the broken bulb.
      Ask FixBot
8 other people completed this guide.
Author
with
jonothon cawley
354 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
72 Guides authored
2 Guide Comments
thanks for instruction…………really helpfull
hebi - Reply Share
Hi guys do you know where to get this bulb?please help
Martin Mitter - Reply Share
Past 24 Hours: 6
Past 7 Days: 39
Past 30 Days: 137
All Time: 8,785
