Up to 20% off select tools
Nikon D90 Bottom Casing Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
35
Past 30 Days:
129
All Time:
6,080
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
The bottom casing of the Nikon D90 can sometimes be scuffed up and damaged. This guide shows how to replace the bottom casing of the Nikon D90. Be forewarned, the screws can be easily be stripped so be careful.
    1. Nikon D90 Bottom Casing Replacement, Bottom Casing: step 1, image 1 of 1
      • Turn the camera so the bottom casing is facing up.
      Ask FixBot
    2. Nikon D90 Bottom Casing Replacement, Removing  Screws from the Bottom Casing: step 2, image 1 of 2 Nikon D90 Bottom Casing Replacement, Removing  Screws from the Bottom Casing: step 2, image 2 of 2
      • Next, use a PH00 screwdriver to remove the screws from the bottom casing.
      • Remove the four 5.3 mm Phillips screws.
      • Remove the three other 6.3 mm Phillips screws.
      • Be careful not to strip the screws.
      Ask FixBot
    3. Nikon D90 Bottom Casing Replacement, Removing the Bottom Case: step 3, image 1 of 2 Nikon D90 Bottom Casing Replacement, Removing the Bottom Case: step 3, image 2 of 2
      • Next, use a plastic opening tool and carefully pop off the bottom case.
      • Then, lift and remove the bottom case.
      Ask FixBot
4 other people completed this guide.
Author
with
Matthew Grota
598 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Member of UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 35
Past 30 Days: 129
All Time: 6,080
