Up to 20% off select tools
Nikon D80 Flash Assembly Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
137
All Time:
3,392
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
After extended use, bulbs often burn out. Replace the flash assembly using this guide. For safety purposes, please remove the battery before working with any electronic components.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
    1. Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 1 of 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 2 of 3 Nikon D80 Flash Assembly Replacement, Flash Assembly: step 1, image 3 of 3
      • Press the highlighted button to pop the flash up.
      • Otherwise, use a plastic opening tool to gently lever open the flash by inserting the tool into the gap between the flash and the camera.
      Ask FixBot
    2. Nikon D80 Flash Assembly Replacement: step 2, image 1 of 1
      • Use the #00 Phillips-head screwdriver to remove both 4.20 mm screws by rotating the screwdriver to the left.
      Ask FixBot
    3. Nikon D80 Flash Assembly Replacement: step 3, image 1 of 2 Nikon D80 Flash Assembly Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, pry open the cover.
      • Be advised, some plastic struts may snap off when you remove the cover.
      Ask FixBot
    4. Nikon D80 Flash Assembly Replacement: step 4, image 1 of 2 Nikon D80 Flash Assembly Replacement: step 4, image 2 of 2
      • Using a soldering iron, desolder the orange, tan, and gray wires from the flash assembly.
      • For more information on how to solder and desolder connections, please visit this guide.
      • Use caution while using the hot soldering iron.
      Ask FixBot
    5. Nikon D80 Flash Assembly Replacement: step 5, image 1 of 1
      • Gently remove the flash assembly from the casing.
      • The surface may still be hot, so grab it with caution.
      Ask FixBot
Author
with
Kevin Horwedel
211 Reputation
1 Guide authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 137
All Time: 3,392
