Up to 20% off select tools
Nikon D80 Bottom Cover Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
135
All Time:
4,186
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In the event that the bottom cover is damaged or specific wires require access, the bottom cover needs to be removed or replaced. For safety purposes, please remove the battery before working with any electronic components.
    1. Nikon D80 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 2 Nikon D80 Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 2
      • Use the #00 Phillips-head screwdriver to remove the three 8.44 mm screws.
      • Use the #00 Phillips-head screwdriver to remove the four 6.3 mm screws.
      • Use the #00 Phillips-head screwdriver to remove the 2.9 mm screw.
      Ask FixBot
    2. Nikon D80 Bottom Cover Replacement: step 2, image 1 of 2 Nikon D80 Bottom Cover Replacement: step 2, image 2 of 2
      • Use the plastic opening tool to remove the bottom cover.
      Ask FixBot
6 other people completed this guide.
Author
with
Sara Martin
610 Reputation
4 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2017 Member of USF Tampa, Team S1-G1, Leahy Fall 2017
USFT-LEAHY-F17S1G1
4 Members
60 Guides authored
1 Guide Comment
The shutter make an attempt to work? It has power! I removed the bottom cover all wires are good?
Dale - Reply Share
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 135
All Time: 4,186
