Nikon D7100 Headphone/Microphone Replacement
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: step 1, image 1 of 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
    Ask FixBot
  2. Nikon D7100 Headphone/Microphone Replacement: step 2, image 1 of 1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
    Ask FixBot
  3. Nikon D7100 Headphone/Microphone Replacement: step 3, image 1 of 1
    • Remove the 2 screws inside the camera on the back corners.
    Ask FixBot
  4. Nikon D7100 Headphone/Microphone Replacement: step 4, image 1 of 1
    • Open the HDMI flap and remove the 2 screws.
    Ask FixBot
  5. Nikon D7100 Headphone/Microphone Replacement: step 5, image 1 of 1
    • Remove the screw next to the camera strap loop.
    Ask FixBot
  6. Nikon D7100 Headphone/Microphone Replacement: step 6, image 1 of 1
    • Remove the 2 screws on each side of the view finder.
    Ask FixBot
  7. Nikon D7100 Headphone/Microphone Replacement: step 7, image 1 of 1
    • Remove the 2 screws above and below the SD card flap.
    Ask FixBot
  8. Nikon D7100 Headphone/Microphone Replacement: step 8, image 1 of 1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
    Ask FixBot
  9. Nikon D7100 Headphone/Microphone Replacement: step 9, image 1 of 2 Nikon D7100 Headphone/Microphone Replacement: step 9, image 2 of 2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
    Ask FixBot
  10. Nikon D7100 Headphone/Microphone Replacement: step 10, image 1 of 1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
    Ask FixBot
  11. Nikon D7100 Headphone/Microphone Replacement: step 11, image 1 of 1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
    Ask FixBot
  12. Nikon D7100 Headphone/Microphone Replacement: step 12, image 1 of 2 Nikon D7100 Headphone/Microphone Replacement: step 12, image 2 of 2
    • Unscrew all 16 screws around the back plate of the camera.
    Ask FixBot
  13. Nikon D7100 Headphone/Microphone Replacement: step 13, image 1 of 1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
    Ask FixBot
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: step 14, image 1 of 1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
    Ask FixBot
  15. Nikon D7100 Headphone/Microphone Replacement: step 15, image 1 of 1
    • Remove the black 4 pin connector by pulling it out of the connector.
    Ask FixBot
  16. Nikon D7100 Headphone/Microphone Replacement: step 16, image 1 of 1
    • Remove the 7 screws holding the motherboard in place.
    Ask FixBot
  17. Nikon D7100 Headphone/Microphone Replacement: step 17, image 1 of 1
    • This is what you should see after removing the motherboard.
    Ask FixBot
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: step 18, image 1 of 1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
    Ask FixBot
Wesley Eveld
754 Reputation
4 Guides authored
USF Tampa, Team S11-G6, Cheng Spring 2018 Member of USF Tampa, Team S11-G6, Cheng Spring 2018
USFT-CHENG-S18S11G6
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,627
