Nikon D7000 Tripod Plate Replacement
  1. Nikon D7000 Tripod Plate Replacement, Motherboard: step 1, image 1 of 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the following 5 screws securing the bottom cover to the camera body:
    • Four 6 mm J000 screws.
    • One 8 mm J000 screw (under lens mount).
    Ask FixBot
  2. Nikon D7000 Tripod Plate Replacement: step 2, image 1 of 1
    • Remove three 6 mm J000 screws from under the battery cover.
    Ask FixBot
  3. Nikon D7000 Tripod Plate Replacement: step 3, image 1 of 2 Nikon D7000 Tripod Plate Replacement: step 3, image 2 of 2
    • Gently pull the bottom cover off of the camera body.
    Ask FixBot
  4. Nikon D7000 Tripod Plate Replacement: step 4, image 1 of 1
    • Remove the following screws from the port area:
    • Two 3.5 mm J000 screws.
    • One 6 mm J000 screw (right above ports).
    Ask FixBot
  5. Nikon D7000 Tripod Plate Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Peel the rear rubber piece off with tweezers.
    Ask FixBot
  6. Nikon D7000 Tripod Plate Replacement: step 6, image 1 of 1
    • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
    Ask FixBot
  7. Nikon D7000 Tripod Plate Replacement: step 7, image 1 of 1
    • Pull the eyepiece cover up to remove it.
    Ask FixBot
  8. Nikon D7000 Tripod Plate Replacement: step 8, image 1 of 1
    • Remove two 6 mm J000 screws from behind the eyepiece cover.
    • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
    Ask FixBot
  9. Nikon D7000 Tripod Plate Replacement: step 9, image 1 of 1
    • Open the SD card cover by pushing slightly down with your thumb and sliding up.
    Ask FixBot
  10. Nikon D7000 Tripod Plate Replacement: step 10, image 1 of 1
    • Remove four 6 mm J000 screws that secure the SD card cover.
    Ask FixBot
  11. Nikon D7000 Tripod Plate Replacement: step 11, image 1 of 1
    • Gently pull the SD card cover off.
    Ask FixBot
  12. Nikon D7000 Tripod Plate Replacement: step 12, image 1 of 1
    • Remove the following screws that secure the back case:
    • One 6 mm J000 screw.
    • One 3 mm J000 screw.
    Ask FixBot
  13. Nikon D7000 Tripod Plate Replacement: step 13, image 1 of 1
    • Carefully lift the back case off.
    Ask FixBot
  14. Nikon D7000 Tripod Plate Replacement: step 14, image 1 of 3 Nikon D7000 Tripod Plate Replacement: step 14, image 2 of 3 Nikon D7000 Tripod Plate Replacement: step 14, image 3 of 3
    • Disconnect the following two ribbon cables from the motherboard.
    • See our Cable Connector Guide for help with ribbon cable connectors!
    Ask FixBot
  15. Nikon D7000 Tripod Plate Replacement: step 15, image 1 of 2 Nikon D7000 Tripod Plate Replacement: step 15, image 2 of 2
    • Remove the following screws securing the left motherboard shield:
    • One 2 mm J000 screw (on the bottom).
    • One 3.5 mm J000 screw (on the back).
    • Be careful of the grounding clips on the motherboard.
    Ask FixBot
  16. Nikon D7000 Tripod Plate Replacement: step 16, image 1 of 1
    • Gently pry and lift the left motherboard shield off.
    Ask FixBot
  17. Nikon D7000 Tripod Plate Replacement: step 17, image 1 of 1
    • Remove one 3.5 mm J000 screw securing the right motherboard shield.
    Ask FixBot
  18. Nikon D7000 Tripod Plate Replacement: step 18, image 1 of 1
    • Gently lift the right motherboard shield off with the tip of a spudger.
    Ask FixBot
  19. Nikon D7000 Tripod Plate Replacement: step 19, image 1 of 3 Nikon D7000 Tripod Plate Replacement: step 19, image 2 of 3 Nikon D7000 Tripod Plate Replacement: step 19, image 3 of 3
    • Disconnect remaining ribbon cables.
    Ask FixBot
  20. Nikon D7000 Tripod Plate Replacement: step 20, image 1 of 2 Nikon D7000 Tripod Plate Replacement: step 20, image 2 of 2
    Ask FixBot
  21. Nikon D7000 Tripod Plate Replacement: step 21, image 1 of 1
    • Carefully disconnect the red connector with tweezers.
    Ask FixBot
  22. Nikon D7000 Tripod Plate Replacement: step 22, image 1 of 1
    • Remove four 3.5 mm J000 screws securing the motherboard.
    Ask FixBot
  23. Nikon D7000 Tripod Plate Replacement: step 23, image 1 of 1
    • Gently pull the port side cover away from the motherboard.
    Ask FixBot
  24. Nikon D7000 Tripod Plate Replacement: step 24, image 1 of 1
    • Lift the motherboard off.
    Ask FixBot
  25. Nikon D7000 Tripod Plate Replacement, Tripod Plate: step 25, image 1 of 1
    • Remove four 6 mm J000 screws securing the tripod plate.
    Ask FixBot
  26. Nikon D7000 Tripod Plate Replacement: step 26, image 1 of 1
    • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
    Ask FixBot
2 other people completed this guide.
Jed Chen
1,865 Reputation
3 Guides authored
Cal Poly, Team 24-6, Lancaster Spring 2015 Member of Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 32
All Time: 2,894
