Nikon D7000 Mirror Box & Viewfinder Replacement
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Motherboard: step 1, image 1 of 1
      • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
      • Remove the following 5 screws securing the bottom cover to the camera body:
      • Four 6 mm J000 screws.
      • One 8 mm J000 screw (under lens mount).
      Ask FixBot
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: step 2, image 1 of 1
      • Remove three 6 mm J000 screws from under the battery cover.
      Ask FixBot
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: step 3, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement: step 3, image 2 of 2
      • Gently pull the bottom cover off of the camera body.
      Ask FixBot
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: step 4, image 1 of 1
      • Remove the following screws from the port area:
      • Two 3.5 mm J000 screws.
      • One 6 mm J000 screw (right above ports).
      Ask FixBot
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Peel the rear rubber piece off with tweezers.
      Ask FixBot
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: step 6, image 1 of 1
      • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
      Ask FixBot
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: step 7, image 1 of 1
      • Pull the eyepiece cover up to remove it.
      Ask FixBot
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: step 8, image 1 of 1
      • Remove two 6 mm J000 screws from behind the eyepiece cover.
      • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
      Ask FixBot
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: step 9, image 1 of 1
      • Open the SD card cover by pushing slightly down with your thumb and sliding up.
      Ask FixBot
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: step 10, image 1 of 1
      • Remove four 6 mm J000 screws that secure the SD card cover.
      Ask FixBot
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: step 11, image 1 of 1
      • Gently pull the SD card cover off.
      Ask FixBot
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: step 12, image 1 of 1
      • Remove the following screws that secure the back case:
      • One 6 mm J000 screw.
      • One 3 mm J000 screw.
      Ask FixBot
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: step 13, image 1 of 1
      • Carefully lift the back case off.
      Ask FixBot
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: step 14, image 1 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 14, image 2 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 14, image 3 of 3
      • Disconnect the following two ribbon cables from the motherboard.
      • See our Cable Connector Guide for help with ribbon cable connectors!
      Ask FixBot
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: step 15, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement: step 15, image 2 of 2
      • Remove the following screws securing the left motherboard shield:
      • One 2 mm J000 screw (on the bottom).
      • One 3.5 mm J000 screw (on the back).
      • Be careful of the grounding clips on the motherboard.
      Ask FixBot
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: step 16, image 1 of 1
      • Gently pry and lift the left motherboard shield off.
      Ask FixBot
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: step 17, image 1 of 1
      • Remove one 3.5 mm J000 screw securing the right motherboard shield.
      Ask FixBot
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: step 18, image 1 of 1
      • Gently lift the right motherboard shield off with the tip of a spudger.
      Ask FixBot
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: step 19, image 1 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 19, image 2 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 19, image 3 of 3
      • Disconnect remaining ribbon cables.
      Ask FixBot
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: step 20, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement: step 20, image 2 of 2
      Ask FixBot
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: step 21, image 1 of 1
      • Carefully disconnect the red connector with tweezers.
      Ask FixBot
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: step 22, image 1 of 1
      • Remove four 3.5 mm J000 screws securing the motherboard.
      Ask FixBot
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: step 23, image 1 of 1
      • Gently pull the port side cover away from the motherboard.
      Ask FixBot
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: step 24, image 1 of 1
      • Lift the motherboard off.
      Ask FixBot
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Tripod Plate: step 25, image 1 of 1
      • Remove four 6 mm J000 screws securing the tripod plate.
      Ask FixBot
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: step 26, image 1 of 1
      • Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
      Ask FixBot
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: step 27, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement, Image Sensor: step 27, image 2 of 2
      • Disconnect black and white speaker cable.
      Ask FixBot
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: step 28, image 1 of 1
      • Remove three 6 mm J000 screws securing the image sensor.
      Ask FixBot
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: step 29, image 1 of 1
      • Carefully lift the image sensor plate out of the camera.
      Ask FixBot
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Shutter Assembly: step 30, image 1 of 1
      • Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
      • It won't take much pressure. Press carefully and the flash will pop up when you find the right spot.
      Ask FixBot
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: step 31, image 1 of 1
      • Remove two 5 mm J000 screws from under the flash.
      Ask FixBot
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: step 32, image 1 of 1
      • Remove two 3 mm J000 screws securing the front cover.
      Ask FixBot
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: step 33, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement: step 33, image 2 of 2
      • Remove the front cover.
      Ask FixBot
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: step 34, image 1 of 1
      • Carefully remove the port cover.
      Ask FixBot
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: step 35, image 1 of 1
      • Deroute the microphone cable.
      Ask FixBot
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: step 36, image 1 of 1
      • Remove one 4 mm J000 screw from the front.
      Ask FixBot
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: step 37, image 1 of 1
      • Remove one 8.5 mm J000 screw from the battery compartment.
      Ask FixBot
    9. Nikon D7000 Mirror Box & Viewfinder Replacement: step 38, image 1 of 1
      • Remove the grip carefully.
      Ask FixBot
    10. Nikon D7000 Mirror Box & Viewfinder Replacement: step 39, image 1 of 1
      • Remove one 4 mm J000 screw securing the top case (under right strap hook).
      Ask FixBot
    11. Nikon D7000 Mirror Box & Viewfinder Replacement: step 40, image 1 of 1
      • Remove one 4 mm J000 screw securing the top case (under left strap hook).
      Ask FixBot
    12. Nikon D7000 Mirror Box & Viewfinder Replacement: step 41, image 1 of 1
      • Remove the sticker covering the diopter adjust screw.
      Ask FixBot
    13. Nikon D7000 Mirror Box & Viewfinder Replacement: step 42, image 1 of 1
      • Remove one 8.0 mm J000 screw.
      • Remove the Diopeter Adjust.
      Ask FixBot
    14. Nikon D7000 Mirror Box & Viewfinder Replacement: step 43, image 1 of 1
      • Remove the top case.
      Ask FixBot
    15. Nikon D7000 Mirror Box & Viewfinder Replacement: step 44, image 1 of 1
      • Remove the Black, Yellow, Green cable from the top case board.
      Ask FixBot
    16. Nikon D7000 Mirror Box & Viewfinder Replacement: step 45, image 1 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 45, image 2 of 3 Nikon D7000 Mirror Box & Viewfinder Replacement: step 45, image 3 of 3
      • Remove two 6.5 mm J000 screws securing the viewfinder.
      • Remove the viewfinder cover.
      Ask FixBot
    17. Nikon D7000 Mirror Box & Viewfinder Replacement: step 46, image 1 of 1
      • Remove one 3 mm J000 screw from the bottom left side of the camera.
      Ask FixBot
    18. Nikon D7000 Mirror Box & Viewfinder Replacement: step 47, image 1 of 1
      • Remove two 6 mm J000 screws from the left of the shutter.
      Ask FixBot
    19. Nikon D7000 Mirror Box & Viewfinder Replacement: step 48, image 1 of 1
      • Remove two 6.5 mm J000 screws from beneath the lens mount.
      Ask FixBot
    20. Nikon D7000 Mirror Box & Viewfinder Replacement: step 49, image 1 of 1
      • Remove two screws from just below and to the sides of the viewfinder.
      Ask FixBot
    21. Nikon D7000 Mirror Box & Viewfinder Replacement: step 50, image 1 of 1
      • Remove one 5 mm J000 screw from the top right of the camera.
      Ask FixBot
    22. Nikon D7000 Mirror Box & Viewfinder Replacement: step 51, image 1 of 1
      • Carefully peel back ribbon cable on the bottom left of camera.
      Ask FixBot
    23. Nikon D7000 Mirror Box & Viewfinder Replacement: step 52, image 1 of 2 Nikon D7000 Mirror Box & Viewfinder Replacement: step 52, image 2 of 2
      • Remove the left front ribbon cable from top right of circuit board.
      Ask FixBot
    24. Nikon D7000 Mirror Box & Viewfinder Replacement: step 53, image 1 of 1
      • Remove all three wire connectors.
      Ask FixBot
    25. Nikon D7000 Mirror Box & Viewfinder Replacement: step 54, image 1 of 1
      • Separate the shutter assembly from the camera body.
      Ask FixBot
    1. Nikon D7000 Mirror Box & Viewfinder Replacement, Mirror Box & Viewfinder: step 55, image 1 of 1
      • Pull out ribbon cable from circuit asembly near front left of device.
      Ask FixBot
    2. Nikon D7000 Mirror Box & Viewfinder Replacement: step 56, image 1 of 1
      • Desolder red & black power leads.
      • Check out our soldering guide for help!
      Ask FixBot
    3. Nikon D7000 Mirror Box & Viewfinder Replacement: step 57, image 1 of 1
      • Disconnect ribbon cable at the top right of camera.
      Ask FixBot
    4. Nikon D7000 Mirror Box & Viewfinder Replacement: step 58, image 1 of 1
      • Disconnect ribbon cable at top right of camera.
      Ask FixBot
    5. Nikon D7000 Mirror Box & Viewfinder Replacement: step 59, image 1 of 1
      • Disconnected ribbon cable at rear right of viewfinder.
      Ask FixBot
    6. Nikon D7000 Mirror Box & Viewfinder Replacement: step 60, image 1 of 1
      • Remove the two 5.5mm J000 screws
      Ask FixBot
    7. Nikon D7000 Mirror Box & Viewfinder Replacement: step 61, image 1 of 1
      • Remove the 5.5 mm J000 screw.
      Ask FixBot
    8. Nikon D7000 Mirror Box & Viewfinder Replacement: step 62, image 1 of 1
      • Remove the viewfinder from the mirror box assembly.
      Ask FixBot
5 other people completed this guide.
Thomas Willson
453 Reputation
1 Guide authored
Cal Poly, Team 24-6, Lancaster Spring 2015 Member of Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Members
60 Guides authored
1 Guide Comment
now I know why my camera failed,, the motor overheated
sir francis - Reply Share
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 83
All Time: 13,902
