Up to 20% off select tools
Nikon D7000 Image Sensor Replacement
Views: 13K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
136
All Time:
12,594
Comments: 29
25 comments on steps, 4 guide comments.
Go to guide comments
Completed: 20
20 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 - 40 minutes
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the image sensor.
Note: You'll need JIS screwdrivers for this repair. Regular Phillips screwdrivers have a cross pattern with rounded inner edges and won't fully fit the slots in the JIS screws. JIS screwdrivers instead have a straight cross pattern which makes much better contact with the screw head and is made for the high torque you will need to loosen the screws.
    1. Nikon D7000 Image Sensor Replacement, Motherboard: step 1, image 1 of 1
      • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
      • Remove the following 5 screws securing the bottom cover to the camera body:
      • Four 6 mm J000 screws.
      • One 8 mm J000 screw (under lens mount).
      Ask FixBot
    2. Nikon D7000 Image Sensor Replacement: step 2, image 1 of 1
      • Remove three 6 mm J000 screws from under the battery cover.
      Ask FixBot
    3. Nikon D7000 Image Sensor Replacement: step 3, image 1 of 2 Nikon D7000 Image Sensor Replacement: step 3, image 2 of 2
      • Gently pull the bottom cover off of the camera body.
      Ask FixBot
    4. Nikon D7000 Image Sensor Replacement: step 4, image 1 of 1
      • Remove the following screws from the port area:
      • Two 3.5 mm J000 screws.
      • One 6 mm J000 screw (right above ports).
      Ask FixBot
    5. Nikon D7000 Image Sensor Replacement: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Peel the rear rubber piece off with tweezers.
      Ask FixBot
    6. Nikon D7000 Image Sensor Replacement: step 6, image 1 of 1
      • Remove one 4.25 mm J000 screw from behind the rear rubber piece.
      Ask FixBot
    7. Nikon D7000 Image Sensor Replacement: step 7, image 1 of 1
      • Pull the eyepiece cover up to remove it.
      Ask FixBot
    8. Nikon D7000 Image Sensor Replacement: step 8, image 1 of 1
      • Remove two 6 mm J000 screws from behind the eyepiece cover.
      • On D7100 models, there is an additional screw holding the back plate on. This screw is located in the diopter (dial with + - on it). This screw can be accessed by peeling up this sticker on the diopter.
      Ask FixBot
    9. Nikon D7000 Image Sensor Replacement: step 9, image 1 of 1
      • Open the SD card cover by pushing slightly down with your thumb and sliding up.
      Ask FixBot
    10. Nikon D7000 Image Sensor Replacement: step 10, image 1 of 1
      • Remove four 6 mm J000 screws that secure the SD card cover.
      Ask FixBot
    11. Nikon D7000 Image Sensor Replacement: step 11, image 1 of 1
      • Gently pull the SD card cover off.
      Ask FixBot
    12. Nikon D7000 Image Sensor Replacement: step 12, image 1 of 1
      • Remove the following screws that secure the back case:
      • One 6 mm J000 screw.
      • One 3 mm J000 screw.
      Ask FixBot
    13. Nikon D7000 Image Sensor Replacement: step 13, image 1 of 1
      • Carefully lift the back case off.
      Ask FixBot
    14. Nikon D7000 Image Sensor Replacement: step 14, image 1 of 3 Nikon D7000 Image Sensor Replacement: step 14, image 2 of 3 Nikon D7000 Image Sensor Replacement: step 14, image 3 of 3
      • Disconnect the following two ribbon cables from the motherboard.
      • See our Cable Connector Guide for help with ribbon cable connectors!
      Ask FixBot
    15. Nikon D7000 Image Sensor Replacement: step 15, image 1 of 2 Nikon D7000 Image Sensor Replacement: step 15, image 2 of 2
      • Remove the following screws securing the left motherboard shield:
      • One 2 mm J000 screw (on the bottom).
      • One 3.5 mm J000 screw (on the back).
      • Be careful of the grounding clips on the motherboard.
      Ask FixBot
    16. Nikon D7000 Image Sensor Replacement: step 16, image 1 of 1
      • Gently pry and lift the left motherboard shield off.
      Ask FixBot
    17. Nikon D7000 Image Sensor Replacement: step 17, image 1 of 1
      • Remove one 3.5 mm J000 screw securing the right motherboard shield.
      Ask FixBot
    18. Nikon D7000 Image Sensor Replacement: step 18, image 1 of 1
      • Gently lift the right motherboard shield off with the tip of a spudger.
      Ask FixBot
    19. Nikon D7000 Image Sensor Replacement: step 19, image 1 of 3 Nikon D7000 Image Sensor Replacement: step 19, image 2 of 3 Nikon D7000 Image Sensor Replacement: step 19, image 3 of 3
      • Disconnect remaining ribbon cables.
      Ask FixBot
    20. Nikon D7000 Image Sensor Replacement: step 20, image 1 of 2 Nikon D7000 Image Sensor Replacement: step 20, image 2 of 2
      Ask FixBot
    21. Nikon D7000 Image Sensor Replacement: step 21, image 1 of 1
      • Carefully disconnect the red connector with tweezers.
      Ask FixBot
    22. Nikon D7000 Image Sensor Replacement: step 22, image 1 of 1
      • Remove four 3.5 mm J000 screws securing the motherboard.
      Ask FixBot
    23. Nikon D7000 Image Sensor Replacement: step 23, image 1 of 1
      • Gently pull the port side cover away from the motherboard.
      Ask FixBot
    24. Nikon D7000 Image Sensor Replacement: step 24, image 1 of 1
      • Lift the motherboard off.
      Ask FixBot
    1. Nikon D7000 Image Sensor Replacement, Image Sensor: step 25, image 1 of 2 Nikon D7000 Image Sensor Replacement, Image Sensor: step 25, image 2 of 2
      • Disconnect black and white speaker cable.
      Ask FixBot
    2. Nikon D7000 Image Sensor Replacement: step 26, image 1 of 1
      • Remove three 6 mm J000 screws securing the image sensor.
      Ask FixBot
    3. Nikon D7000 Image Sensor Replacement: step 27, image 1 of 1
      • Carefully lift the image sensor plate out of the camera.
      Ask FixBot
20 other people completed this guide.
Author
with
Jed Chen
1,865 Reputation
3 Guides authored
Cal Poly, Team 24-6, Lancaster Spring 2015 Member of Cal Poly, Team 24-6, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G6
3 Members
60 Guides authored
4 Guide Comments
I really need to do this operation! One question: I’m shopping for a replacement sensor and in the photos it looks like the cables off the sensor assembly are free hanging. In this tutorial there is only the disconnection of the black and white speaker cables. Where do these cables go?
Sean McDonald - Reply Share
I am grateful for this! Thanks - it worked a treat!
Peter Davies - Reply Share
Thanks, I have done it with the Nikon d7200, it is different I have made some comments already, similar to the Nikon d7100 you have to unscrew the diopter and has 2 screws under the rubber what you have to remove… The motherboard is totally different
Rudi Zimmerer - Reply Share
Any suggestions for locating a reputable, OEM part? Tons of choices on eBay with widely varying prices. Hints or clues to ensure I am buying authentic and safe parts are appreciated! Thanks!
George Peters - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 136
All Time: 12,594
