Up to 20% off select tools
Nikon D700 Screen Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
Past 7 Days:
40
Past 30 Days:
182
All Time:
3,324
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
If your Nikon D700 screen needs to be replaced because it is broken/faulty, use this guide to replace your Nikon D700 screen.
    1. Nikon D700 Screen Replacement, Screen: step 1, image 1 of 1
      Tool used on this step:
      iOpener
      $24.95
      Buy
      • Use a spudger and your hands to remove the front grip cover, held together by an adhesive.
      • You may need to use heat to loosen up the adhesive. Try using the iOpener.
      • Under the rubber cover, use a screwdriver to remove one screw on the top right corner.
      Ask FixBot
    2. Nikon D700 Screen Replacement: step 2, image 1 of 2 Nikon D700 Screen Replacement: step 2, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the five screws that hold the cover in place.
      Ask FixBot
    3. Nikon D700 Screen Replacement: step 3, image 1 of 1
      • Gently remove the screen by pulling the top away from the body.
      • The screen is connected by wires on the bottom, so be careful when taking the screen off.
      Ask FixBot
    4. Nikon D700 Screen Replacement: step 4, image 1 of 3 Nikon D700 Screen Replacement: step 4, image 2 of 3 Nikon D700 Screen Replacement: step 4, image 3 of 3
      Buy
      • To remove the screen entirely, use a spudger to unlock the connectors.
      • Pull the cables out gently using tweezers or your spudger.
      Ask FixBot
    5. Nikon D700 Screen Replacement: step 5, image 1 of 2 Nikon D700 Screen Replacement: step 5, image 2 of 2
      • The screen should be completely detached from the camera and can now be replaced with a new screen.
      Ask FixBot
Author
with
Leandro Neves
227 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 40
Past 30 Days: 182
All Time: 3,324
