Up to 20% off select tools
Nikon D700 Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
122
All Time:
2,024
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds - 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your Nikon D700 battery needs to be replaced because the it has come to the end of its life or you notice it doesn't hold a charge anymore, use this guide to remove and replace your Nikon D700 battery.
The battery provides power for your camera and is necessary for the camera to function.
Make sure your camera is powered off before removing the battery from your Nikon D700 camera.
    1. Nikon D700 Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the camera over so the bottom is facing up and you'll see the battery cover.
      • To open the battery latch, press the latch release from right to left, and the cover should pop open.
      Ask FixBot
    2. Nikon D700 Battery Replacement: step 2, image 1 of 3 Nikon D700 Battery Replacement: step 2, image 2 of 3 Nikon D700 Battery Replacement: step 2, image 3 of 3
      • Remove the battery.
      • When replacing the battery, make sure to match the diagram on the battery cover door.
      Ask FixBot
Author
with
Leandro Neves
227 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 122
All Time: 2,024
