Up to 20% off select tools
Nikon D70 Memory Compression Board Replacement
Views: 25K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
101
All Time:
24,700
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the memory compression board.
    1. Nikon D70 Memory Compression Board Replacement, Battery: step 1, image 1 of 1
      • Use your finger tip to pull the battery release tab toward the center of the D70.
      • Open the battery door and rotate it away from the bottom cover.
      Ask FixBot
    2. Nikon D70 Memory Compression Board Replacement: step 2, image 1 of 1
      • Pull the battery out of the D70.
      • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
      Ask FixBot
    1. Nikon D70 Memory Compression Board Replacement, Bottom Cover: step 3, image 1 of 1
      • Remove the following eight screws securing the bottom cover to the D70:
      • Six 5.8 mm Phillips screws
      • One 10.7 mm Phillips screws
      • One 8.2 mm Phillips screws
      Ask FixBot
    2. Nikon D70 Memory Compression Board Replacement: step 4, image 1 of 2 Nikon D70 Memory Compression Board Replacement: step 4, image 2 of 2
      • Carefully pull the bottom cover to separate it from the body of the D70.
      • Remove the bottom cover from the D70.
      Ask FixBot
    1. Nikon D70 Memory Compression Board Replacement, Memory Compression Board: step 5, image 1 of 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: step 5, image 2 of 3 Nikon D70 Memory Compression Board Replacement, Memory Compression Board: step 5, image 3 of 3
      • Remove the four ZIF ribbon cables highlighted in red by using the following procedure:
      • Use your fingernail to flip up the ZIF cable retaining flap on each socket.
      • Be sure you are prying up the retaining flap, not the socket.
      • Pull the ribbon cable straight out of its socket.
      Ask FixBot
    2. Nikon D70 Memory Compression Board Replacement: step 6, image 1 of 1
      • Carefully peel back the piece of tape covering the Compact Flash ribbon cable socket.
      • It is not necessary to completely remove this piece of tape.
      Ask FixBot
    3. Nikon D70 Memory Compression Board Replacement: step 7, image 1 of 3 Nikon D70 Memory Compression Board Replacement: step 7, image 2 of 3 Nikon D70 Memory Compression Board Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Use your fingernails to carefully pull the ZIF cable lock away from its socket.
      • Do not try to completely remove the ZIF cable lock. It will move about 1 mm and stop.
      • Use a pair of tweezers to pull the Compact Flash ribbon cable out of its socket.
      Ask FixBot
    4. Nikon D70 Memory Compression Board Replacement: step 8, image 1 of 1
      • Be sure not to lose the small iron core around the DC-In ribbon cable.
      Ask FixBot
    5. Nikon D70 Memory Compression Board Replacement: step 9, image 1 of 1
      • Remove the four 4.3 mm Phillips screws securing the memory compression board to the D70.
      Ask FixBot
    6. Nikon D70 Memory Compression Board Replacement: step 10, image 1 of 1
      • Use a pair of tweezers to pull the USB connector bracket away from the edge of the memory compression board.
      Ask FixBot
    7. Nikon D70 Memory Compression Board Replacement: step 11, image 1 of 2 Nikon D70 Memory Compression Board Replacement: step 11, image 2 of 2
      • Grab the memory compression board by its edges at the position shown in the first picture.
      • Pull the memory compression board straight up off the DC/DC board to avoid damaging the connector on the underside of the memory compression board.
      Ask FixBot
4 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 101
All Time: 24,700
