Up to 20% off select tools
Nikon D5200 Screen Replacement
Views: 15K
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
196
All Time:
14,814
Comments: 13
2 comments on steps, 11 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Make sure to have your soldering iron ready prior to replacing the screen. This will make the process go faster as the time it takes to heat the soldering iron varies.
    1. Nikon D5200 Screen Replacement, Screen: step 1, image 1 of 3 Nikon D5200 Screen Replacement, Screen: step 1, image 2 of 3 Nikon D5200 Screen Replacement, Screen: step 1, image 3 of 3
      • Fully open the LCD panel so that its screws are easily accessible.
      • Remove the two 2.5 mm screws from the outside edge of the screen casing, and the two 3.5 mm screws from the inside edge.
      Ask FixBot
    2. Nikon D5200 Screen Replacement: step 2, image 1 of 3 Nikon D5200 Screen Replacement: step 2, image 2 of 3 Nikon D5200 Screen Replacement: step 2, image 3 of 3
      • Pry open the plastic casing using the opening tool or by hand.
      Ask FixBot
    3. Nikon D5200 Screen Replacement: step 3, image 1 of 3 Nikon D5200 Screen Replacement: step 3, image 2 of 3 Nikon D5200 Screen Replacement: step 3, image 3 of 3
      • Use the plastic opening tool to pop up the latch holding the ribbon cable on the right side of the circuit board, and remove it.
      • Use the plastic opening tool to pry the ribbon cable on the left side of the circuit board up and off of its socket.
      Ask FixBot
    4. Nikon D5200 Screen Replacement: step 4, image 1 of 2 Nikon D5200 Screen Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, unplug the smaller cable.
      Ask FixBot
    5. Nikon D5200 Screen Replacement: step 5, image 1 of 2 Nikon D5200 Screen Replacement: step 5, image 2 of 2
      • Desolder the three small wires on the left side of the circuit board.
      • Soldering irons become very hot when in use. Take all necessary precautions to avoid injury.
      Ask FixBot
    6. Nikon D5200 Screen Replacement: step 6, image 1 of 3 Nikon D5200 Screen Replacement: step 6, image 2 of 3 Nikon D5200 Screen Replacement: step 6, image 3 of 3
      • Using a spudger, remove the display from its casing.
      Ask FixBot
15 other people completed this guide.
Author
with
Alexander Corn
1,363 Reputation
5 Guides authored
USF Tampa, Team 3-1, Eyestone Fall 2015 Member of USF Tampa, Team 3-1, Eyestone Fall 2015
USFT-EYESTONE-F15S3G1
4 Members
60 Guides authored
11 Guide Comments
Do I need to de-solder if I'm just replacing the window glass?
isaac - Reply Share
To isaac: no. The exterior glass is separate from the LCD.
Joseph Morris - Reply Share
Do you recommend the replacent for LCD sold on Ebay?
g_atki - Reply Share
Where did you find the replacement screen? The one I ordered that says it's for the d5200 is not the same as the one in it or in your pictures.
Heather Miller - Reply Share
How do you disconnect the multi-plug that is shown connected in image 4 and disconnected in image five? Does it unclip or slide out?
Amanda Bruyninckx - Reply Share
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 196
All Time: 14,814
