Up to 20% off select tools
Nikon D5100 Memory Card Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
27
Past 30 Days:
119
All Time:
3,498
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Your camera stores images and data on an SD memory card. This guide will teach you how to locate and replace this memory card.
    1. Nikon D5100 Memory Card Replacement, Memory Card: step 1, image 1 of 3 Nikon D5100 Memory Card Replacement, Memory Card: step 1, image 2 of 3 Nikon D5100 Memory Card Replacement, Memory Card: step 1, image 3 of 3
      • Open the memory card compartment door, located to the right of the digital display, by using your thumb to push it in the direction of the arrow.
      Ask FixBot
    2. Nikon D5100 Memory Card Replacement: step 2, image 1 of 1
      • Eject the memory card by pressing it into its slot until you hear a soft "click."
      Ask FixBot
    3. Nikon D5100 Memory Card Replacement: step 3, image 1 of 1
      • Using thumb and forefinger, gently remove the SD card from its slot.
      Ask FixBot
Author
with
Liz
1,428 Reputation
5 Guides authored
Cal Poly, Team 10-54, Amido Spring 2014 Member of Cal Poly, Team 10-54, Amido Spring 2014
CPSU-AMIDO-S14S10G54
4 Members
60 Guides authored
1 Guide Comment
isn't this procedure in the user manual?
Happy Fixer - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 119
All Time: 3,498
