Nikon D5100 Battery Door Replacement
  1. Nikon D5100 Battery Door Replacement, Battery Door: step 1, image 1 of 3 Nikon D5100 Battery Door Replacement, Battery Door: step 1, image 2 of 3 Nikon D5100 Battery Door Replacement, Battery Door: step 1, image 3 of 3
    • Insert the battery into the battery compartment at the bottom of the camera.
    Ask FixBot
  2. Nikon D5100 Battery Door Replacement: step 2, image 1 of 3 Nikon D5100 Battery Door Replacement: step 2, image 2 of 3 Nikon D5100 Battery Door Replacement: step 2, image 3 of 3
    • Take the mending plate and place it over the threaded hole at the bottom of the camera.
    • Make sure the mending plate is covering the battery compartment.
    • Hold the mending plate in position.
    Ask FixBot
  3. Nikon D5100 Battery Door Replacement: step 3, image 1 of 3 Nikon D5100 Battery Door Replacement: step 3, image 2 of 3 Nikon D5100 Battery Door Replacement: step 3, image 3 of 3
    • While holding down the mending plate, take the screw and place it on top of the mending plate and over the threaded hole.
    • Push the screw into the threaded hole and turn clockwise to screw in.
    • Tighten the screw by using a screwdriver.
    Ask FixBot
  4. Nikon D5100 Battery Door Replacement: step 4, image 1 of 1
    • The metal bar should be attached and tightly secured.
    Ask FixBot
  5. Nikon D5100 Battery Door Replacement: step 5, image 1 of 2 Nikon D5100 Battery Door Replacement: step 5, image 2 of 2
    • Turn on the camera to check that the battery is properly secure.
    Ask FixBot
Finish Line
2 other people completed this guide.
Michelle Tran
155 Reputation
1 Guide authored
Cal Poly, Team 23-1, Green Winter 2015 Member of Cal Poly, Team 23-1, Green Winter 2015
CPSU-GREEN-W15S23G1
4 Members
4 Guides authored
1 Guide Comment
My son broke the battery door and I kept it somewhere now it's gone
Chiaki - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 53
All Time: 3,549
