Nikon D500 Top Panel Removal
      • Remove the Memory Card(s) from the camera
      • Remove the Battery from the Camera, and close the battery compartment cover
      Ask FixBot
    1. Nikon D500 Top Panel Removal, Remove 2 exposed screws: step 2, image 1 of 1
      • Remove the 2 screws beside the memory slots, then close the cover.
      • Note: make sure to remove the memory cards first!
      Ask FixBot
    2. Nikon D500 Top Panel Removal, Remove 2 screws under grip: step 3, image 1 of 1
      • Remove the 2 screws under the rubber grip part by peeling back the rubber grip
      • Try not to damage the double sided adhesive under the rubber.
      Ask FixBot
    3. Nikon D500 Top Panel Removal, Remove 2 screws under rear grip: step 4, image 1 of 1
      • Remove the 2 screws under the rubber pad marked in red.
      • Try not to damage the double-sided adhesive under the rubber.
      • Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
      Ask FixBot
      • Lift out the assembly panel, it should come free without much force.
      • May open the panel to release it.
      Ask FixBot
    1. Nikon D500 Top Panel Removal, Remove top screw: step 6, image 1 of 1
      • Remove the screw above the viewfinder
      Ask FixBot
    2. Nikon D500 Top Panel Removal, Remove the bottom panel plate: step 7, image 1 of 1
      • Remove the 4 screws holding the plate to the bottom.
      • Remove the bottom plate
      Ask FixBot
    3. Nikon D500 Top Panel Removal, Remove screws from the bottom: step 8, image 1 of 1
      • Remove the 4 screws (1 was under the plate removed under the last step)
      Ask FixBot
    4. Nikon D500 Top Panel Removal, Remove Screw under grip: step 9, image 1 of 1
      • Remove the screw under the grip, if it has not been removed doing a previous step
      Ask FixBot
    5. Nikon D500 Top Panel Removal, Remove Screw on Left: step 10, image 1 of 1
      • Remove the exposed screw on the Left side
      Ask FixBot
    6. Nikon D500 Top Panel Removal, Carefully remove the back assembly: step 11, image 1 of 1
      • Carefully pull the back plate off the camera
      • There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
      • To release the cables by flipping up the tap on the side away from the cable
      • When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
      • The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
      • The black LCD cable does have less slack, so is easier to release first, and reconnect last.
      Ask FixBot
    1. Nikon D500 Top Panel Removal, Remove Grip: step 12, image 1 of 1
      • Carefully remove the Rubber grip from the camera
      • Careful to not damage the double-sided adhesive
      Ask FixBot
    2. Nikon D500 Top Panel Removal, Remove the Left Rubber: step 13, image 1 of 1
      Ask FixBot
    3. Nikon D500 Top Panel Removal, Disconnect the diopter: step 14, image 1 of 1
      • Remove the diopter cap from the end of the diopter (use a flat head or pry tool)
      • Un-screw the phillips screw from the diopter
      • When reconnecting, make sure the cap is seated in correctly and the double sided tape is not damaged (or replace)
      • There is a notch which the indicator has to seat into, or it will not sit down correctly when it is reinstalled.
      Ask FixBot
    4. Nikon D500 Top Panel Removal, Remove Screw on Right: step 15, image 1 of 1
      • Remove the screw that had been hidden under the memory slot cover.
      Ask FixBot
    5. Nikon D500 Top Panel Removal, Remove Front Screws: step 16, image 1 of 1
      • Remove the screw under the top assembly, had been hidden by the grip.
      • Remove the 2 screws from the bottom of the mirror box
      • Remove the lens or lenscap prior to doing this step to gain access, then reattach.
      • Remove the screw from beside the accessory socket
      Ask FixBot
    6. Nikon D500 Top Panel Removal, Remove Screw on Left: step 17, image 1 of 1
      • Remove the screw from the left side, had been hidden under the rubber
      Ask FixBot
    7. Nikon D500 Top Panel Removal, Disconnect from main board: step 18, image 1 of 1
      • Disconnect the 2 ribbon cables from the main board (Red boxes)
      • Lift the black tabs above the cables to release the cables
      • When reseating the cables, make sure they are fully seated before closing the locking tab
      • Note: there is another ribbon cable under the left one which goes to the 10-pin accessory port, make sure it's seated correctly when reassembling.
      • Disconnect the wifi sub-board with the wifi cable from the main board (Blue Box) or gently disconnect the wifi antenna (Blue circle)
      • The antenna connector is very delicate, and isn't designed for many cycles, which is why the board is recommended (it has a socket it fits into.
      Ask FixBot
    8. Nikon D500 Top Panel Removal, Lift Top assembly free: step 19, image 1 of 3 Nikon D500 Top Panel Removal, Lift Top assembly free: step 19, image 2 of 3 Nikon D500 Top Panel Removal, Lift Top assembly free: step 19, image 3 of 3
      • Carefully lift the top assembly free.
      • Note, there is a thermal pad on the left hand side, almost right under where the strap lug is. Red Box. Careful to not damage it.
      Ask FixBot
Careful of the thermal pad on the left side when placing the top assembly back onto the camera.
Wolphin
1,795 Reputation
9 Guides authored
2 Guide Comments
could you do a d5?
davenelsonpix - Reply Share
Yes, I could, if you provide me with a D5 to make the guide. :)
Wolphin - Reply Share
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 55
All Time: 2,584
