Up to 20% off select tools
Nikon D40 Viewfinder Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
129
All Time:
4,468
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • iFixit Opening Tool
    4.8
Introduction
Go to step 1 ↓
This guide will help to you access your viewfinder in your Nikon D40 and replace the viewfinder.
    1. Nikon D40 Viewfinder Replacement, Back Cover: step 1, image 1 of 1
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      Ask FixBot
    2. Nikon D40 Viewfinder Replacement: step 2, image 1 of 2 Nikon D40 Viewfinder Replacement: step 2, image 2 of 2
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      Ask FixBot
    3. Nikon D40 Viewfinder Replacement: step 3, image 1 of 1
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      Ask FixBot
    4. Nikon D40 Viewfinder Replacement: step 4, image 1 of 1
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      Ask FixBot
    1. Nikon D40 Viewfinder Replacement, Viewfinder: step 5, image 1 of 1
      • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
      • Be careful not to pull too hard on the ribbon cables.
      Ask FixBot
    2. Nikon D40 Viewfinder Replacement: step 6, image 1 of 1
      • Slowly push the upper body up until you see the frame of the viewfinder
      • Be careful while pulling the top camera body.
      Ask FixBot
    3. Nikon D40 Viewfinder Replacement: step 7, image 1 of 1
      • Use a spudger to keep the upper body separate from the printed circuit board.
      • Wiggle the plastic eyepiece out of the frame. This may require some force.
      Ask FixBot
    4. Nikon D40 Viewfinder Replacement: step 8, image 1 of 1
      • Remove the viewfinder with the plastic opening tool.
      • Do not push too hard while using the opening tool.
      Ask FixBot
    5. Nikon D40 Viewfinder Replacement: step 9, image 1 of 1
      • The viewfinder has been removed!
      Ask FixBot
2 other people completed this guide.
Author
with
Amy Chen
193 Reputation
1 Guide authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 129
All Time: 4,468
