Up to 20% off select tools
Nikon D40 Mainboard Replacement
Views: 5.6K
View statistics:
Past 24 Hours:
9
Past 7 Days:
37
Past 30 Days:
127
All Time:
5,597
Comments: 4
1 comment on steps, 3 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
The mainboard controls all of the software on the Nikon D40. A faulty mainboard can cause problems that will require a new board. This guide will show you how to replace the camera's mainboard.
    1. Nikon D40 Mainboard Replacement, Back Cover: step 1, image 1 of 1
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      Ask FixBot
    2. Nikon D40 Mainboard Replacement: step 2, image 1 of 2 Nikon D40 Mainboard Replacement: step 2, image 2 of 2
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      Ask FixBot
    3. Nikon D40 Mainboard Replacement: step 3, image 1 of 1
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      Ask FixBot
    4. Nikon D40 Mainboard Replacement: step 4, image 1 of 1
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      Ask FixBot
    1. Nikon D40 Mainboard Replacement, Mainboard: step 5, image 1 of 2 Nikon D40 Mainboard Replacement, Mainboard: step 5, image 2 of 2
      • Remove the solder connecting the red wire to the mainboard.
      Ask FixBot
    2. Nikon D40 Mainboard Replacement: step 6, image 1 of 1
      • Desolder the 4 smaller wires near the bottom of the mainboard.
      Ask FixBot
    3. Nikon D40 Mainboard Replacement: step 7, image 1 of 2 Nikon D40 Mainboard Replacement: step 7, image 2 of 2
      • Use the plastic opening tool to release the ribbon cables attached to the mainboard.
      Ask FixBot
    4. Nikon D40 Mainboard Replacement: step 8, image 1 of 1
      • Remove the five 3.0mm Philips #1 screws holding the mainboard down.
      Ask FixBot
    5. Nikon D40 Mainboard Replacement: step 9, image 1 of 2 Nikon D40 Mainboard Replacement: step 9, image 2 of 2
      • Lift the mainboard up to reveal the final connection.
      • Carefully detach the white cable from the board.
      Ask FixBot
7 other people completed this guide.
Author
with
Joe Leija
632 Reputation
2 Guides authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
72 Guides authored
3 Guide Comments
What is the ordering of the small wires on the bottom? It is hard to put back together from the photos. Thanks!
Joseph Ruskiewicz - Reply Share
wheres the power source? i mean the fuse
Gringo Maputi - Reply Share
in the main board located kindly put markings on it
Past 24 Hours: 9
Past 7 Days: 37
Past 30 Days: 127
All Time: 5,597
