Up to 20% off select tools
Nikon D40 Flash Pin Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
37
Past 30 Days:
130
All Time:
5,079
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to open up your flash safely and replace the flash pin that holds the flash upright.
    1. Nikon D40 Flash Pin Replacement, Flash Pin: step 1, image 1 of 1
      • Turn off the camera and remove the battery.
      Ask FixBot
    2. Nikon D40 Flash Pin Replacement: step 2, image 1 of 1
      • Pry the flash open using the plastic opening tool.
      Ask FixBot
    3. Nikon D40 Flash Pin Replacement: step 3, image 1 of 1
      • Remove the two Phillips #0 3.0 mm screws from the front of the flash compartment using the small Phillips Head screwdriver.
      Ask FixBot
    4. Nikon D40 Flash Pin Replacement: step 4, image 1 of 2 Nikon D40 Flash Pin Replacement: step 4, image 2 of 2
      • Pry off the back plastic of the flash compartment using the plastic opening tool.
      • When it is time to reassemble the flash module, a certain amount of force and precise alignment will be required.
      Ask FixBot
    5. Nikon D40 Flash Pin Replacement: step 5, image 1 of 2 Nikon D40 Flash Pin Replacement: step 5, image 2 of 2
      • On the left of the camera you will see a metal spring.
      • Unscrew the Phillips #0 3.0 mm screw holding the spring in place, using the small Phillips Head screwdriver.
      Ask FixBot
    6. Nikon D40 Flash Pin Replacement: step 6, image 1 of 1
      • Remove metal spring and replace with new spring.
      Ask FixBot
4 other people completed this guide.
Author
with
Lindsey Chase
227 Reputation
1 Guide authored
Cal Poly, Team 6-19, Maness Winter 2014 Member of Cal Poly, Team 6-19, Maness Winter 2014
CPSU-MANESS-W14S6G19
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 37
Past 30 Days: 130
All Time: 5,079
