Up to 20% off select tools
Nikon D3200 Memory Card Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
25
Past 30 Days:
119
All Time:
5,944
Comments: 1
1 guide comment.
Go to guide comments
Completed: 12
12 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Confirm with your user's manual for appropriate memory cards.
    1. Nikon D3200 Memory Card Replacement, Memory Card: step 1, image 1 of 1
      • Locate the memory card compartment on the right side of the LCD screen.
      Ask FixBot
    2. Nikon D3200 Memory Card Replacement: step 2, image 1 of 3 Nikon D3200 Memory Card Replacement: step 2, image 2 of 3 Nikon D3200 Memory Card Replacement: step 2, image 3 of 3
      • Gently press and slide the grooved compartment door to the left.
      • Let go of the compartment door and it will swing open.
      • Insert the memory card imitating the diagram pictured outside the compartment door.
      • Make sure to push down once the memory card is inserted to lock it in place.
      Ask FixBot
12 other people completed this guide.
Author
with
Irene Huang
724 Reputation
3 Guides authored
CSU Fullerton, Team 1-3, Bruce Fall 2014 Member of CSU Fullerton, Team 1-3, Bruce Fall 2014
CSUF-BRUCE-F14S1G3
6 Members
48 Guides authored
1 Guide Comment
Hello is this about replacing the memory card compartment or just the memory card? Apparently the memory card compartment is not maintining the memory, it’s not keeping it in the memor slot keeps popping back up. How do I fix this? Can I replace the housing?
Joseph Antonio - Reply Share
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 119
All Time: 5,944
