Nikon D3000 Motherboard Replacement
    1. Nikon D3000 Motherboard Replacement, Motherboard: step 1, image 1 of 2 Nikon D3000 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
      • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
      • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
      Ask FixBot
    2. Nikon D3000 Motherboard Replacement: step 2, image 1 of 3 Nikon D3000 Motherboard Replacement: step 2, image 2 of 3 Nikon D3000 Motherboard Replacement: step 2, image 3 of 3
      • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
      • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
      • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
      Ask FixBot
    3. Nikon D3000 Motherboard Replacement: step 3, image 1 of 2 Nikon D3000 Motherboard Replacement: step 3, image 2 of 2
      • Use the following process for removing all ribbon connectors.
      • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
      • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
      Ask FixBot
    4. Nikon D3000 Motherboard Replacement: step 4, image 1 of 2 Nikon D3000 Motherboard Replacement: step 4, image 2 of 2
      • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
      • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
      • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
      • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
      • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
      Ask FixBot
    5. Nikon D3000 Motherboard Replacement: step 5, image 1 of 2 Nikon D3000 Motherboard Replacement: step 5, image 2 of 2
      • Lift the tabs and pull away the ribbon connectors shown .
      • Lift the motherboard and disconnect the grey connector from the bottom.
      • Disconnect and remove the motherboard.
      Ask FixBot
3 other people completed this guide.
Randall Heath
899 Reputation
3 Guides authored
USF Tampa, Team 14-7, Meier Fall 2015 Member of USF Tampa, Team 14-7, Meier Fall 2015
USFT-MEIER-F15S14G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 46
All Time: 4,956
