Up to 20% off select tools
Nikon D3000 Flash Spring Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
112
All Time:
4,264
Comments: 0
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Easy
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
After removing the covering of the flash arm and it's components, remove the metal spring from it's hinge and replace it with a new one.
    1. Nikon D3000 Flash Spring Replacement, Flash Spring: step 1, image 1 of 2 Nikon D3000 Flash Spring Replacement, Flash Spring: step 1, image 2 of 2
      • Remove the two 2.5mm x 4mm Philips screws located directly under the flash.
      • Pop off the covering of the flash to reveal the flash arm spring.
      Ask FixBot
    2. Nikon D3000 Flash Spring Replacement: step 2, image 1 of 1
      • Lift the flash arm spring using the plastic spudger and unhinge the spring to remove it.
      Ask FixBot
    3. Nikon D3000 Flash Spring Replacement: step 3, image 1 of 1
      • Remove the spring by sliding it off, then replace it with a new one.
      Ask FixBot
7 other people completed this guide.
Author
with
Zahra Simpson
310 Reputation
1 Guide authored
WeFiXiTT Member of WeFiXiTT
Community
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 112
All Time: 4,264
