Nikon Coolpix S9700 Back Panel Replacement
    1. Nikon Coolpix S9700 Back Panel Replacement, Battery: step 1, image 1 of 2 Nikon Coolpix S9700 Back Panel Replacement, Battery: step 1, image 2 of 2
      • Press the ON/OFF button to power off the S9700.
      • Not doing so can damage the S9700 or cause electric shock.
      Ask FixBot
    2. Nikon Coolpix S9700 Back Panel Replacement: step 2, image 1 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 2, image 2 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 2, image 3 of 3
      • Place the S9700 upside down
      • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
      • The cover will open up by itself.
      Ask FixBot
    3. Nikon Coolpix S9700 Back Panel Replacement: step 3, image 1 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 3, image 2 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 3, image 3 of 3
      • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
      Ask FixBot
    4. Nikon Coolpix S9700 Back Panel Replacement: step 4, image 1 of 2 Nikon Coolpix S9700 Back Panel Replacement: step 4, image 2 of 2
      • Grab the battery and pull out.
      Ask FixBot
    1. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: step 5, image 1 of 2 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: step 5, image 2 of 2
      • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
      • Three 3-mm screws are on the side opposite the battery compartment.
      • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
      Ask FixBot
    2. Nikon Coolpix S9700 Back Panel Replacement: step 6, image 1 of 2 Nikon Coolpix S9700 Back Panel Replacement: step 6, image 2 of 2
      • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
      • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
      • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
      Ask FixBot
    3. Nikon Coolpix S9700 Back Panel Replacement: step 7, image 1 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 7, image 2 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 7, image 3 of 3
      • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
      • Twist the plastic opening tool so that both halves separate.
      • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
      • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
      Ask FixBot
    4. Nikon Coolpix S9700 Back Panel Replacement: step 8, image 1 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 8, image 2 of 3 Nikon Coolpix S9700 Back Panel Replacement: step 8, image 3 of 3
      • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
      • Gently remove the back panel.
      Ask FixBot
Matt Staubus
849 Reputation
5 Guides authored
USF Tampa, Team 9-5, Lacy Fall 2016 Member of USF Tampa, Team 9-5, Lacy Fall 2016
USFT-LACY-F16S9G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,608
