Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
62
All Time:
1,063
Comments: 4
3 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The reader will learn how to replace the back panel/touch screen of the Nikon Coolpix S800c. This may be necessary due to body damage or an improperly working screen that may be defective or cracked screen.
Parts
Tools
    1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: step 1, image 1 of 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: step 1, image 2 of 2
      • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
      Ask FixBot
    2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: step 2, image 1 of 2 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: step 2, image 2 of 2
      • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
      Ask FixBot
2 other people completed this guide.
Ilyasah Muhammad
234 Reputation
2 Guides authored
Baylor, Team S2-G6, Johnson Spring 2018 Member of Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Members
60 Guides authored
1 Guide Comment
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Brian Capouch - Reply Share
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 62
All Time: 1,063
