Nikon Coolpix S7000 Shutter Button Replacement
    1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: step 1, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: step 1, image 2 of 2
      • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
      • Screw locations.
      Ask FixBot
    2. Nikon Coolpix S7000 Shutter Button Replacement: step 2, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement: step 2, image 2 of 2
      • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
      Ask FixBot
    3. Nikon Coolpix S7000 Shutter Button Replacement: step 3, image 1 of 2 Nikon Coolpix S7000 Shutter Button Replacement: step 3, image 2 of 2
      • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
      • Black tape.
      • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
      Ask FixBot
    4. Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 1 of 3 Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 2 of 3 Nikon Coolpix S7000 Shutter Button Replacement: step 4, image 3 of 3
      • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
      • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
      • Locations of the two screws.
      • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
      Ask FixBot
Nicholas Leon-Schetina
116 Reputation
1 Guide authored
USF Tampa, Team S2-G3, Lacy Spring 2017 Member of USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
4 Members
60 Guides authored
1 Guide Comment
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,187
