Nikon Coolpix S6800 Button Assembly Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
87
All Time:
1,420
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will allow you to disassemble the camera to the point where the button assembly can be replaced, help you replace it and provide direction for reassembly.
Tools
    1. Nikon Coolpix S6800 Button Assembly Replacement, Midframe: step 1, image 1 of 1
      • Turn the camera upside down and locate the two, black screws.
      • Using the Philips #00 Screwdriver, remove each screw.
      Ask FixBot
    2. Nikon Coolpix S6800 Button Assembly Replacement: step 2, image 1 of 1
      • Rotate the camera to the left side and remove the two, black, #00 Philips screws.
      Ask FixBot
    3. Nikon Coolpix S6800 Button Assembly Replacement: step 3, image 1 of 1
      • Rotate the camera to the right side and remove the two, black, #00 Philips screws.
      • The last screw that you remove will catch as the cover is trying to pop off. Try to keep the cover in place to allow for the screw to just fall out. Once you remove the screws, be careful not to lose the screws for reassembly.
      Ask FixBot
    4. Nikon Coolpix S6800 Button Assembly Replacement: step 4, image 1 of 1
      • Carefully remove the back plate from the body of the camera.
      • All of the external screws are black with rounded heads.
      Ask FixBot
    5. Nikon Coolpix S6800 Button Assembly Replacement: step 5, image 1 of 1
      • Using the Philips #00 Screwdriver, remove the two screws that are holding the keypad.
      Ask FixBot
    6. Nikon Coolpix S6800 Button Assembly Replacement: step 6, image 1 of 2 Nikon Coolpix S6800 Button Assembly Replacement: step 6, image 2 of 2
      • Flip the keypad away from the camera
      • Be careful with the electric ribbon. Do not crease it or tug on it. Gently flip it away from the camera.
      Ask FixBot
    7. Nikon Coolpix S6800 Button Assembly Replacement: step 7, image 1 of 2 Nikon Coolpix S6800 Button Assembly Replacement: step 7, image 2 of 2
      • Gently pull the display away from the camera body.
      • Fold the display away from the camera
      • Be careful with the display. Do not press on it or drop it.
      Ask FixBot
    8. Nikon Coolpix S6800 Button Assembly Replacement: step 8, image 1 of 2 Nikon Coolpix S6800 Button Assembly Replacement: step 8, image 2 of 2
      • Remove the visible midframe screws.
      • There is a screw beneath the foam square that must be removed as well.
      • The screw holding the silver wrist-strap loop on the side of the camera must also be removed.
      • Gently lift the midframe up and out of the device.
      • Be careful moving the midframe away from the ribbons don't force it, gently slide the plate away from the ribbons.
      Ask FixBot
    1. Nikon Coolpix S6800 Button Assembly Replacement, Button Assembly: step 9, image 1 of 2 Nikon Coolpix S6800 Button Assembly Replacement, Button Assembly: step 9, image 2 of 2
      • Flip up the little tan tab on the connecter of the button pad's ribbon.
      • Don't use a metal object for this step. A fingernail will do. Simply slide your fingernail under the lip and lift slowly. You may need to lift in different areas along the tab to get it all the way up.
      • In the second image the top tab is open while the bottom is closed as an example of what the two positions look like.
      • The tab is reversed for the button pad, the tan part is the tab while the black is the connector
      Ask FixBot
    2. Nikon Coolpix S6800 Button Assembly Replacement: step 10, image 1 of 1
      • Gently pull out the ribbon. It should come out easily, don't force it.
      Ask FixBot
    3. Nikon Coolpix S6800 Button Assembly Replacement: step 11, image 1 of 1
      • Take the new button pad and orient it the same way as the old pad before it was removed.
      • Gently slide the end of the electric ribbon into the connector.
      • To make sure that the ribbon is completely in the connector give it a firm push but don't force anything. The ribbon should slide in with only a little resistance.
      • The ribbon is flexible so it may bend but take care NOT to crease it.
      Ask FixBot
sam ford
518 Reputation
4 Guides authored
1 Guide Comment
Where can I purchase the button assembly for this model? Does this assembly also control the lens function? When I depress the button, sometimes the lens open then closes. Thank you for your wonderful clear instructions.
Elegant - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 87
All Time: 1,420
