Nikon Coolpix S6300 Display Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
78
All Time:
2,520
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide shows how to replace a broken display
Tools
    1. Nikon Coolpix S6300 Display Replacement, Battery: step 1, image 1 of 1
      • Place the camera facing upwards.
      • Press down on the battery cover and slide towards the front face of the camera.
      Ask FixBot
    2. Nikon Coolpix S6300 Display Replacement: step 2, image 1 of 1
      • Rotate the orange battery clip in the camera to release the battery.
      Ask FixBot
    1. Nikon Coolpix S6300 Display Replacement, Buttons: step 3, image 1 of 3 Nikon Coolpix S6300 Display Replacement, Buttons: step 3, image 2 of 3 Nikon Coolpix S6300 Display Replacement, Buttons: step 3, image 3 of 3
      • Locate the eight outer PH 2mm screws on the device.
      • Using the PH00 screwdriver remove all of the screws from the camera.
      Ask FixBot
    2. Nikon Coolpix S6300 Display Replacement: step 4, image 1 of 3 Nikon Coolpix S6300 Display Replacement: step 4, image 2 of 3 Nikon Coolpix S6300 Display Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, gently pry off the front and rear plates.
      • Be patient with this step, do not force the clips holding the plates together.
      Ask FixBot
    3. Nikon Coolpix S6300 Display Replacement: step 5, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the PH 2 mm screw located to the right of the screen, above the OK dial.
      Ask FixBot
    4. Nikon Coolpix S6300 Display Replacement: step 6, image 1 of 1
      • Disconnect the connectors using a plastic spudger.
      • Be careful when removing the cables to prevent damaging the connectors.
      Ask FixBot
    5. Nikon Coolpix S6300 Display Replacement: step 7, image 1 of 1
      • You may now remove the internal panel of the buttons.
      Ask FixBot
    1. Nikon Coolpix S6300 Display Replacement, Display: step 8, image 1 of 1
      • Remove the clasp from the ribbon cable using the plastic spudger.
      • Make sure to be gentle when removing the clasp to prevent it from ripping.
      • You may now remove the display.
      Ask FixBot
Hung
386 Reputation
2 Guides authored
USF Tampa, Team 1-2, Remmell Fall 2015 Member of USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
5 Members
60 Guides authored
2 Guide Comments
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Reply Share
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 78
All Time: 2,520
