Nikon Coolpix S630 Shutter Button Replacement
    1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: step 1, image 1 of 1
      • The battery compartment is located on the bottom of the camera.
      • Place your thumb on the battery door.
      • Slide the door away from the camera in the direction the arrow points to.
      Ask FixBot
    2. Nikon Coolpix S630 Shutter Button Replacement, Battery: step 2, image 1 of 1
      • Slide the yellow tab towards the back of the camera.
      • The battery should pop out.
      • Remove the battery.
      Ask FixBot
    1. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: step 3, image 1 of 1
      • Press the memory card down into the camera.
      • The memory card should pop out.
      • Remove the memory card.
      Ask FixBot
    1. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: step 4, image 1 of 1
      • Locate a small, rectangular flap above the battery cover door.
      • Push the small, rectangular flap back through the hole.
      Ask FixBot
    2. Nikon Coolpix S630 Shutter Button Replacement: step 5, image 1 of 1
      • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
      • Make sure to hold the camera down when removing the front cover.
      Ask FixBot
    1. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: step 6, image 1 of 1
      • Place the front cover facing down so that you can easily see the shutter button.
      Ask FixBot
    2. Nikon Coolpix S630 Shutter Button Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, gently slide the shutter button out.
      • Be very gentle because you can damage the piece.
      Ask FixBot
Aulivia Bounchaleun
10 Reputation
4 Guides authored
Cal Poly, Team 8-56, Johann Spring 2013 Member of Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 44
All Time: 2,940
