Nikon Coolpix S630 Back Cover Replacement
  1. Nikon Coolpix S630 Back Cover Replacement, Battery Compartment: step 1, image 1 of 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
    Ask FixBot
  2. Nikon Coolpix S630 Back Cover Replacement, Battery: step 2, image 1 of 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
    Ask FixBot
  3. Nikon Coolpix S630 Back Cover Replacement, Memory Card: step 3, image 1 of 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
    Ask FixBot
  4. Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: step 4, image 1 of 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: step 4, image 2 of 3 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: step 4, image 3 of 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
    Ask FixBot
  5. Nikon Coolpix S630 Back Cover Replacement: step 5, image 1 of 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
    Ask FixBot
  6. Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: step 6, image 1 of 2 Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
    Ask FixBot
Anna Katrina
28 Reputation
2 Guides authored
Cal Poly, Team 8-56, Johann Spring 2013 Member of Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 35
All Time: 904
