Nikon Coolpix S5300 Outer Casing Replacement
    1. Nikon Coolpix S5300  Outer Casing Replacement, Battery: step 1, image 1 of 1
      • Turn the camera upside down and locate the battery compartment.
      • Slide the compartment open following the direction of the arrow.
      Ask FixBot
    2. Nikon Coolpix S5300  Outer Casing Replacement: step 2, image 1 of 1
      • Press the orange release button to release and remove the battery.
      • Replace or insert battery in it's respective terminals
      Ask FixBot
    1. Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement, Outer Casing: step 3, image 3 of 3
      • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
      • Using the same screwdriver, remove the 2 screws on the side of the camera.
      • Remove the 2 screws from the other side of the camera.
      • One of the screws is under the I/O port cover.
      Ask FixBot
    2. Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 4, image 3 of 3
      • Use the plastic opening tool to carefully separate the cover from the camera.
      • Work the plastic opening tool around all the edges of the front plate.
      • Pull the purple plastic cover off gently from the screen.
      Ask FixBot
    3. Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 1 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 2 of 3 Nikon Coolpix S5300  Outer Casing Replacement: step 5, image 3 of 3
      • Turn the camera over so the LCD screen is facing you.
      • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
      Ask FixBot
    4. Nikon Coolpix S5300  Outer Casing Replacement: step 6, image 1 of 2 Nikon Coolpix S5300  Outer Casing Replacement: step 6, image 2 of 2
      • Be careful to keep track of little pieces of the outside casing.
      Ask FixBot
    5. Nikon Coolpix S5300  Outer Casing Replacement: step 7, image 1 of 2 Nikon Coolpix S5300  Outer Casing Replacement: step 7, image 2 of 2
      • Carefully remove the top button casing by pulling it away from main camera.
      Ask FixBot
Riordan McCole
307 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 18
All Time: 468
