Nikon Coolpix S51c Lens Replacement
    1. Nikon Coolpix S51c Lens Replacement, Back Cover: step 1, image 1 of 2 Nikon Coolpix S51c Lens Replacement, Back Cover: step 1, image 2 of 2
      • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
      Ask FixBot
    2. Nikon Coolpix S51c Lens Replacement: step 2, image 1 of 1
      • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
      • Remove this screw using the Phillips #00 screwdriver.
      Ask FixBot
    3. Nikon Coolpix S51c Lens Replacement: step 3, image 1 of 1
      • Rotate the camera to find the side panel with the lanyard attachment.
      • Detach the side panel by the lifting bottom corner slightly with the spudger.
      Ask FixBot
    4. Nikon Coolpix S51c Lens Replacement: step 4, image 1 of 1
      • Lift the back cover.
      • Be careful not to rip the orange cables between the camera and the back cover.
      Ask FixBot
    5. Nikon Coolpix S51c Lens Replacement: step 5, image 1 of 1
      • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
      • Carefully remove the back cover.
      Ask FixBot
    1. Nikon Coolpix S51c Lens Replacement, Lens: step 6, image 1 of 3 Nikon Coolpix S51c Lens Replacement, Lens: step 6, image 2 of 3 Nikon Coolpix S51c Lens Replacement, Lens: step 6, image 3 of 3
      • Remove the five screws on the metal plate.
      • One of them is in a hole in the corner of the metal plate.
      • Remove the screw at the bottom of the camera.
      • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
      Ask FixBot
    2. Nikon Coolpix S51c Lens Replacement: step 7, image 1 of 2 Nikon Coolpix S51c Lens Replacement: step 7, image 2 of 2
      • Lift the white flap with the spudger to release the ribbon.
      • Remove the back metal plate.
      Ask FixBot
    3. Nikon Coolpix S51c Lens Replacement: step 8, image 1 of 3 Nikon Coolpix S51c Lens Replacement: step 8, image 2 of 3 Nikon Coolpix S51c Lens Replacement: step 8, image 3 of 3
      • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
      Ask FixBot
Ryan
167 Reputation
6 Guides authored
Cal Poly, Team 18-24, Garner Spring 2011 Member of Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Members
72 Guides authored
2 Guide Comments
question: any source for replacement lens block ? can't find any on the internet
Cyrille Dupuydauby - Reply Share
question: any source for lens block ? I can't find any on the internet
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 38
All Time: 2,383
