Nikon Coolpix S51c LCD Screen Replacement
  1. Nikon Coolpix S51c LCD Screen Replacement, Back Cover: step 1, image 1 of 2 Nikon Coolpix S51c LCD Screen Replacement, Back Cover: step 1, image 2 of 2
    • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
    Ask FixBot
  2. Nikon Coolpix S51c LCD Screen Replacement: step 2, image 1 of 1
    • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using the Phillips #00 screwdriver.
    Ask FixBot
  3. Nikon Coolpix S51c LCD Screen Replacement: step 3, image 1 of 1
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
    Ask FixBot
  4. Nikon Coolpix S51c LCD Screen Replacement: step 4, image 1 of 1
    • Lift the back cover.
    • Be careful not to rip the orange cables between the camera and the back cover.
    Ask FixBot
  5. Nikon Coolpix S51c LCD Screen Replacement: step 5, image 1 of 1
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
    • Carefully remove the back cover.
    Ask FixBot
  6. Nikon Coolpix S51c LCD Screen Replacement, LCD Screen: step 6, image 1 of 1
    • On back of LCD screen, locate the three screws underneath the ribbon.
    • Remove each screw using your screwdriver.
    Ask FixBot
  7. Nikon Coolpix S51c LCD Screen Replacement: step 7, image 1 of 2 Nikon Coolpix S51c LCD Screen Replacement: step 7, image 2 of 2
    • Take out the rectangular component on the side where the screws were.
    • Carefully, pry apart the screen from the back casing using the spudger.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Ryan
167 Reputation
6 Guides authored
Cal Poly, Team 18-24, Garner Spring 2011 Member of Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 49
All Time: 2,972
