Nikon Coolpix S51c Back Cover Replacement
    1. Nikon Coolpix S51c Back Cover Replacement, Back Cover: step 1, image 1 of 2 Nikon Coolpix S51c Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • First, use a Phillips #00 screwdriver to remove all five screws that are located at the bottom of the camera.
      Ask FixBot
    2. Nikon Coolpix S51c Back Cover Replacement: step 2, image 1 of 1
      • Next, slide the battery door open in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
      • Remove this screw using the Phillips #00 screwdriver.
      Ask FixBot
    3. Nikon Coolpix S51c Back Cover Replacement: step 3, image 1 of 1
      • Rotate the camera to find the side panel with the lanyard attachment.
      • Detach the side panel by the lifting bottom corner slightly with the spudger.
      Ask FixBot
    4. Nikon Coolpix S51c Back Cover Replacement: step 4, image 1 of 1
      • Lift the back cover.
      • Be careful not to rip the orange cables between the camera and the back cover.
      Ask FixBot
    5. Nikon Coolpix S51c Back Cover Replacement: step 5, image 1 of 1
      • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger.
      • Carefully remove the back cover.
      Ask FixBot
2 other people completed this guide.
Ryan
167 Reputation
6 Guides authored
Cal Poly, Team 18-24, Garner Spring 2011 Member of Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 14
Past 30 Days: 34
All Time: 1,805
