Nikon Coolpix S4100 Lens Replacement
  1. Nikon Coolpix S4100 Lens Replacement, External Casing: step 1, image 1 of 3 Nikon Coolpix S4100 Lens Replacement, External Casing: step 1, image 2 of 3 Nikon Coolpix S4100 Lens Replacement, External Casing: step 1, image 3 of 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
    Ask FixBot
  2. Nikon Coolpix S4100 Lens Replacement: step 2, image 1 of 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
    Ask FixBot
  3. Nikon Coolpix S4100 Lens Replacement: step 3, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
    Ask FixBot
  4. Nikon Coolpix S4100 Lens Replacement: step 4, image 1 of 3 Nikon Coolpix S4100 Lens Replacement: step 4, image 2 of 3 Nikon Coolpix S4100 Lens Replacement: step 4, image 3 of 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
    Ask FixBot
  5. Nikon Coolpix S4100 Lens Replacement: step 5, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
    Ask FixBot
  6. Nikon Coolpix S4100 Lens Replacement: step 6, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 6, image 2 of 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
    Ask FixBot
  7. Nikon Coolpix S4100 Lens Replacement: step 7, image 1 of 3 Nikon Coolpix S4100 Lens Replacement: step 7, image 2 of 3 Nikon Coolpix S4100 Lens Replacement: step 7, image 3 of 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
    Ask FixBot
  8. Nikon Coolpix S4100 Lens Replacement: step 8, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
    Ask FixBot
  9. Nikon Coolpix S4100 Lens Replacement: step 9, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
    Ask FixBot
  10. Nikon Coolpix S4100 Lens Replacement: step 10, image 1 of 1
    • Remove the remaining side shell casing.
    Ask FixBot
  11. Nikon Coolpix S4100 Lens Replacement: step 11, image 1 of 1
    • Remove the top shell casing.
    Ask FixBot
  12. Nikon Coolpix S4100 Lens Replacement, Functional Button Plate: step 12, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
    Ask FixBot
  13. Nikon Coolpix S4100 Lens Replacement: step 13, image 1 of 1
    Tool used on this step:
    Buy
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
    Ask FixBot
  14. Nikon Coolpix S4100 Lens Replacement: step 14, image 1 of 1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
    Ask FixBot
  15. Nikon Coolpix S4100 Lens Replacement, LCD Screen: step 15, image 1 of 2 Nikon Coolpix S4100 Lens Replacement, LCD Screen: step 15, image 2 of 2
    Buy
    • Using precision tweezers, gently remove the ribbon cable running from LCD to the bottom side of the motherboard.
    Ask FixBot
  16. Nikon Coolpix S4100 Lens Replacement: step 16, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 16, image 2 of 2
    • Using precision tweezers, gently lift up on the black strip of the ZIF Connector securing the cable from the LCD to the motherboard.
    • Then, gently remove the wire by pulling the base of the ribbon cable towards the LCD screen.
    • Do not poke or destroy the cable itself. Be careful to only grab the black fold in the tweezers.
    • The black strip will fold back to reveal the cable, but remain attached to the motherboard.
    Ask FixBot
  17. Nikon Coolpix S4100 Lens Replacement: step 17, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 17, image 2 of 2
    • Remove the LCD screen from the metal mount.
    Ask FixBot
  18. Nikon Coolpix S4100 Lens Replacement, Lens: step 18, image 1 of 2 Nikon Coolpix S4100 Lens Replacement, Lens: step 18, image 2 of 2
    • Using a Philips #000 head screwdriver, remove 7 Philips head screws of length 3.4mm from the metal LCD camera mount.
    Ask FixBot
  19. Nikon Coolpix S4100 Lens Replacement: step 19, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 19, image 2 of 2
    Buy
    • Using precision tweezers, gently lift up on the black strip of the first ZIF Connector securing the cable from the lens to the connector on the motherboard.
    • The black strip will fold back, but remain attached to the connector.
    Ask FixBot
  20. Nikon Coolpix S4100 Lens Replacement: step 20, image 1 of 1
    • Using precision tweezers, grab the base of the first ribbon cable and pull out parallel to the metal mount.
    Ask FixBot
  21. Nikon Coolpix S4100 Lens Replacement: step 21, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 21, image 2 of 2
    • Using precision tweezers, gently lift up on the black strip of the second ZIF Connector securing the cable from the lens to the connector on the motherboard.
    Ask FixBot
  22. Nikon Coolpix S4100 Lens Replacement: step 22, image 1 of 2 Nikon Coolpix S4100 Lens Replacement: step 22, image 2 of 2
    • Using precision tweezers, grab the base of the second ribbon cable and pull out parallel to the metal mount.
    Ask FixBot
  23. Nikon Coolpix S4100 Lens Replacement: step 23, image 1 of 3 Nikon Coolpix S4100 Lens Replacement: step 23, image 2 of 3 Nikon Coolpix S4100 Lens Replacement: step 23, image 3 of 3
    • Using a plastic spudger, pry open the 4 clamps on the exterior of the screen mount.
    • Separate the screen mount and the lens.
    Ask FixBot
  24. Nikon Coolpix S4100 Lens Replacement: step 24, image 1 of 3 Nikon Coolpix S4100 Lens Replacement: step 24, image 2 of 3 Nikon Coolpix S4100 Lens Replacement: step 24, image 3 of 3
    • Using a plastic spudger, pry the 3 metal clamps away from the lens.
    • The metal clamps are located on the perimeter of the lens.
    • Remove the lens.
    Ask FixBot
3 other people completed this guide.
Matthew Willis
598 Reputation
4 Guides authored
Baylor, Team 4-2, Williams Fall 2015 Member of Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Members
8 Guides authored
1 Guide Comment
My screws too stripped. But I thought this would be easy as the discription. Fix your jammed lens!. I haven't fully investigated my ipod touch 5th generation. Which battery needs to be removed to see the flipped side, it looks dirty near the board. Maybe I read wrong… but anyways. That's the best I done…. I just panic. Will try again when I get a screw driver. Or get a magic flash card. That's some folk lore I will try.
Salina - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 70
All Time: 2,495
