Nikon Coolpix S4100 Functional Button Plate Replacement
  1. Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: step 1, image 1 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: step 1, image 2 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement, External Casing: step 1, image 3 of 3
    • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
    • There are 2 on each side, and 4 on the bottom.
    Ask FixBot
  2. Nikon Coolpix S4100 Functional Button Plate Replacement: step 2, image 1 of 1
    • Remove the black casing on the back of the camera that runs around the LCD screen.
    Ask FixBot
  3. Nikon Coolpix S4100 Functional Button Plate Replacement: step 3, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
    Ask FixBot
  4. Nikon Coolpix S4100 Functional Button Plate Replacement: step 4, image 1 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement: step 4, image 2 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement: step 4, image 3 of 3
    • Pry off the front shell casing.
    • If you find this difficult, use a prying tool to help gently remove the casing.
    Ask FixBot
  5. Nikon Coolpix S4100 Functional Button Plate Replacement: step 5, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
    Ask FixBot
  6. Nikon Coolpix S4100 Functional Button Plate Replacement: step 6, image 1 of 2 Nikon Coolpix S4100 Functional Button Plate Replacement: step 6, image 2 of 2
    • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
    Ask FixBot
  7. Nikon Coolpix S4100 Functional Button Plate Replacement: step 7, image 1 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement: step 7, image 2 of 3 Nikon Coolpix S4100 Functional Button Plate Replacement: step 7, image 3 of 3
    • Remove the lanyard mount and accompanying side shell casing off of the camera.
    Ask FixBot
  8. Nikon Coolpix S4100 Functional Button Plate Replacement: step 8, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
    Ask FixBot
  9. Nikon Coolpix S4100 Functional Button Plate Replacement: step 9, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
    Ask FixBot
  10. Nikon Coolpix S4100 Functional Button Plate Replacement: step 10, image 1 of 1
    • Remove the remaining side shell casing.
    Ask FixBot
  11. Nikon Coolpix S4100 Functional Button Plate Replacement: step 11, image 1 of 1
    • Remove the top shell casing.
    Ask FixBot
  12. Nikon Coolpix S4100 Functional Button Plate Replacement, Functional Button Plate: step 12, image 1 of 1
    • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located near the functional buttons.
    Ask FixBot
  13. Nikon Coolpix S4100 Functional Button Plate Replacement: step 13, image 1 of 1
    Tool used on this step:
    Buy
    • Using precision tweezers, remove the ribbon cable that runs from the functional buttons plate to the under side of the motherboard.
    Ask FixBot
  14. Nikon Coolpix S4100 Functional Button Plate Replacement: step 14, image 1 of 1
    • Using precision tweezers, lift up the bottom of the functional buttons plate and remove the metal plate.
    Ask FixBot
Matthew Willis
598 Reputation
4 Guides authored
Baylor, Team 4-2, Williams Fall 2015 Member of Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 38
All Time: 693
