Nikon Coolpix S4100 External Casing Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
103
All Time:
1,704
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
In this guide, you will find instructions on how to properly remove the entire external casing of the camera. This guide will reveal the inner components of the camera. From here, you can replace the casing if it is broken, or access other internal parts of the camera.
Tools
    1. Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement, External Casing: step 1, image 3 of 3
      • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
      • There are 2 on each side, and 4 on the bottom.
      Ask FixBot
    2. Nikon Coolpix S4100 External Casing Replacement: step 2, image 1 of 1
      • Remove the black casing on the back of the camera that runs around the LCD screen.
      Ask FixBot
    3. Nikon Coolpix S4100 External Casing Replacement: step 3, image 1 of 1
      • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
      Ask FixBot
    4. Nikon Coolpix S4100 External Casing Replacement: step 4, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement: step 4, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement: step 4, image 3 of 3
      • Pry off the front shell casing.
      • If you find this difficult, use a prying tool to help gently remove the casing.
      Ask FixBot
    5. Nikon Coolpix S4100 External Casing Replacement: step 5, image 1 of 1
      • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
      Ask FixBot
    6. Nikon Coolpix S4100 External Casing Replacement: step 6, image 1 of 2 Nikon Coolpix S4100 External Casing Replacement: step 6, image 2 of 2
      • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
      Ask FixBot
    7. Nikon Coolpix S4100 External Casing Replacement: step 7, image 1 of 3 Nikon Coolpix S4100 External Casing Replacement: step 7, image 2 of 3 Nikon Coolpix S4100 External Casing Replacement: step 7, image 3 of 3
      • Remove the lanyard mount and accompanying side shell casing off of the camera.
      Ask FixBot
    8. Nikon Coolpix S4100 External Casing Replacement: step 8, image 1 of 1
      • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
      Ask FixBot
    9. Nikon Coolpix S4100 External Casing Replacement: step 9, image 1 of 1
      • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
      Ask FixBot
    10. Nikon Coolpix S4100 External Casing Replacement: step 10, image 1 of 1
      • Remove the remaining side shell casing.
      Ask FixBot
    11. Nikon Coolpix S4100 External Casing Replacement: step 11, image 1 of 1
      • Remove the top shell casing.
      Ask FixBot
2 other people completed this guide.
Matthew Willis
598 Reputation
4 Guides authored
Baylor, Team 4-2, Williams Fall 2015 Member of Baylor, Team 4-2, Williams Fall 2015
BU-WILLIAMS-F15S4G2
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 1,704
