Nikon Coolpix S4000 Lense Casing Replacement
    1. Nikon Coolpix S4000 Lense Casing Replacement, Battery: step 1, image 1 of 1
      • Slide the battery door open with a finger or thumb and release it so the door opens.
      Ask FixBot
    2. Nikon Coolpix S4000 Lense Casing Replacement: step 2, image 1 of 1
      • Push the orange tab back and the battery will pop out.
      Ask FixBot
    1. Nikon Coolpix S4000 Lense Casing Replacement, Casing: step 3, image 1 of 3 Nikon Coolpix S4000 Lense Casing Replacement, Casing: step 3, image 2 of 3 Nikon Coolpix S4000 Lense Casing Replacement, Casing: step 3, image 3 of 3
      • Remove four 2mm Phillips #000 screws.
      • Remove two black 3mm Phillips #000 screws.
      • Remove one 4mm Phillips #000 screws.
      • Remove two silver 3mm Phillips #000 screws.
      Ask FixBot
    2. Nikon Coolpix S4000 Lense Casing Replacement: step 4, image 1 of 2 Nikon Coolpix S4000 Lense Casing Replacement: step 4, image 2 of 2
      • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
      Ask FixBot
    3. Nikon Coolpix S4000 Lense Casing Replacement: step 5, image 1 of 3 Nikon Coolpix S4000 Lense Casing Replacement: step 5, image 2 of 3 Nikon Coolpix S4000 Lense Casing Replacement: step 5, image 3 of 3
      • Turn the camera over.
      • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
      Ask FixBot
    1. Nikon Coolpix S4000 Lense Casing Replacement, Lens Casing: step 6, image 1 of 1
      • Remove the single 3mm Phillips #000 screw from the back of the camera.
      Ask FixBot
    2. Nikon Coolpix S4000 Lense Casing Replacement: step 7, image 1 of 2 Nikon Coolpix S4000 Lense Casing Replacement: step 7, image 2 of 2
      • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
      • Desolder the two wires connecting the casing to the motherboard.
      • Work carefully so that you do not break the soldered wires.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 724
