Nikon Coolpix S4000 Lens Replacement
    1. Nikon Coolpix S4000 Lens Replacement, Battery: step 1, image 1 of 1
      • Slide the battery door open with a finger or thumb and release it so the door opens.
      Ask FixBot
    2. Nikon Coolpix S4000 Lens Replacement: step 2, image 1 of 1
      • Push the orange tab back and the battery will pop out.
      Ask FixBot
    1. Nikon Coolpix S4000 Lens Replacement, Casing: step 3, image 1 of 3 Nikon Coolpix S4000 Lens Replacement, Casing: step 3, image 2 of 3 Nikon Coolpix S4000 Lens Replacement, Casing: step 3, image 3 of 3
      • Remove four 2mm Phillips #000 screws.
      • Remove two black 3mm Phillips #000 screws.
      • Remove one 4mm Phillips #000 screws.
      • Remove two silver 3mm Phillips #000 screws.
      Ask FixBot
    2. Nikon Coolpix S4000 Lens Replacement: step 4, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 4, image 2 of 2
      • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
      Ask FixBot
    3. Nikon Coolpix S4000 Lens Replacement: step 5, image 1 of 3 Nikon Coolpix S4000 Lens Replacement: step 5, image 2 of 3 Nikon Coolpix S4000 Lens Replacement: step 5, image 3 of 3
      • Turn the camera over.
      • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
      Ask FixBot
    1. Nikon Coolpix S4000 Lens Replacement, Lens Casing: step 6, image 1 of 1
      • Remove the single 3mm Phillips #000 screw from the back of the camera.
      Ask FixBot
    2. Nikon Coolpix S4000 Lens Replacement: step 7, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 7, image 2 of 2
      • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
      • Desolder the two wires connecting the casing to the motherboard.
      • Work carefully so that you do not break the soldered wires.
      Ask FixBot
    1. Nikon Coolpix S4000 Lens Replacement, Screen: step 8, image 1 of 1
      • Remove the single 2mm Phillips #000 screw.
      Ask FixBot
    2. Nikon Coolpix S4000 Lens Replacement: step 9, image 1 of 3 Nikon Coolpix S4000 Lens Replacement: step 9, image 2 of 3 Nikon Coolpix S4000 Lens Replacement: step 9, image 3 of 3
      • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
      • Pull the ribbon cables out of the ZIF connectors.
      Ask FixBot
    3. Nikon Coolpix S4000 Lens Replacement: step 10, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 10, image 2 of 2
      • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
      Ask FixBot
    1. Nikon Coolpix S4000 Lens Replacement, Lens: step 11, image 1 of 2 Nikon Coolpix S4000 Lens Replacement, Lens: step 11, image 2 of 2
      • Remove the two 3mm Phillips #000 screws.
      Ask FixBot
    2. Nikon Coolpix S4000 Lens Replacement: step 12, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 12, image 2 of 2
      • Turn the camera over and remove a single 4mm Phillips #000 screw.
      • There may be black tape covering the screw.
      Ask FixBot
    3. Nikon Coolpix S4000 Lens Replacement: step 13, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 13, image 2 of 2
      • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
      Ask FixBot
    4. Nikon Coolpix S4000 Lens Replacement: step 14, image 1 of 2 Nikon Coolpix S4000 Lens Replacement: step 14, image 2 of 2
      • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
      • The tabs are brittle so use gently force.
      Ask FixBot
    5. Nikon Coolpix S4000 Lens Replacement: step 15, image 1 of 1
      • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
      • Pull the orange ribbon cable out of the ZIF connector.
      • Separate the lens from the motherboard.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 82
All Time: 2,097
