Nikon Coolpix S3500 Shutter Release Button Replacement
  1. Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: step 1, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement, Back Panel Disassembly: step 1, image 2 of 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
    Ask FixBot
  2. Nikon Coolpix S3500 Shutter Release Button Replacement: step 2, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement: step 2, image 2 of 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
    Ask FixBot
  3. Nikon Coolpix S3500 Shutter Release Button Replacement: step 3, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement: step 3, image 2 of 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
    Ask FixBot
  4. Nikon Coolpix S3500 Shutter Release Button Replacement: step 4, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement: step 4, image 2 of 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
    Ask FixBot
  5. Nikon Coolpix S3500 Shutter Release Button Replacement: step 5, image 1 of 3 Nikon Coolpix S3500 Shutter Release Button Replacement: step 5, image 2 of 3 Nikon Coolpix S3500 Shutter Release Button Replacement: step 5, image 3 of 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
    Ask FixBot
  6. Nikon Coolpix S3500 Shutter Release Button Replacement: step 6, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement: step 6, image 2 of 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
    Ask FixBot
  7. Nikon Coolpix S3500 Shutter Release Button Replacement, Shutter Release Button: step 7, image 1 of 1
    • Place the device shutter side down onto your hand.
    Ask FixBot
  8. Nikon Coolpix S3500 Shutter Release Button Replacement: step 8, image 1 of 3 Nikon Coolpix S3500 Shutter Release Button Replacement: step 8, image 2 of 3 Nikon Coolpix S3500 Shutter Release Button Replacement: step 8, image 3 of 3
    • Take the thumb of the hand holding the device and place it on the plastic front panel.
    • Make sure to be gentle so no damage is done to any of the inner components of the device.
    • With your free hand, grip the outer edge of the LCD screen and start to pull the LCD from the front panel of the device.
    • This should cause the two pieces to separate from each other.
    Ask FixBot
  9. Nikon Coolpix S3500 Shutter Release Button Replacement: step 9, image 1 of 2 Nikon Coolpix S3500 Shutter Release Button Replacement: step 9, image 2 of 2
    • Now that the 2 pieces are separated, take your free hand and gently press down on the shutter release button.
    • This should cause the shutter release button to come free from the front panel of the device.
    Ask FixBot
2 other people completed this guide.
Jordan Rosemeyer
518 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 34
All Time: 1,125
