Nikon Coolpix S3100 Camera Shutter Button Replacement
    1. Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: step 1, image 1 of 3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: step 1, image 2 of 3 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: step 1, image 3 of 3
      • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
      • Remove 2 screws from left side. (picture 1)
      • Remove 4 screws from bottom. (picture 2)
      • Remove 2 screws from right side. (picture 3)
      Ask FixBot
    2. Nikon Coolpix S3100 Camera Shutter Button Replacement: step 2, image 1 of 2 Nikon Coolpix S3100 Camera Shutter Button Replacement: step 2, image 2 of 2
      • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
      • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
      • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
      Ask FixBot
    3. Nikon Coolpix S3100 Camera Shutter Button Replacement: step 3, image 1 of 2 Nikon Coolpix S3100 Camera Shutter Button Replacement: step 3, image 2 of 2
      • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
      • Remove the two screws.
      • Gently pull up to detach the frame. (picture 2)
      Ask FixBot
    1. Nikon Coolpix S3100 Camera Shutter Button Replacement, Shutter Button: step 4, image 1 of 1
      • Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
      • Be very carefully handling the spring as it could release from tweezer.
      Ask FixBot
    2. Nikon Coolpix S3100 Camera Shutter Button Replacement: step 5, image 1 of 1
      • Gently remove the black adhesive tape.
      Ask FixBot
    3. Nikon Coolpix S3100 Camera Shutter Button Replacement: step 6, image 1 of 1
      • Remove 2-2.90mm using a #000 Phillips screwdriver.
      Ask FixBot
    4. Nikon Coolpix S3100 Camera Shutter Button Replacement: step 7, image 1 of 1
      • The camera shutter is now apart.
      Ask FixBot
2 other people completed this guide.
Jorge
1,248 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 911
