Nikon Coolpix S30 LCD Screen Replacement
  1. Nikon Coolpix S30 LCD Screen Replacement, Batteries: step 1, image 1 of 2 Nikon Coolpix S30 LCD Screen Replacement, Batteries: step 1, image 2 of 2
    • Slide the battery cover to the right.
    • The hinge is on the left side of the cover which will allow the cover to stay attached.
    Ask FixBot
  2. Nikon Coolpix S30 LCD Screen Replacement: step 2, image 1 of 2 Nikon Coolpix S30 LCD Screen Replacement: step 2, image 2 of 2
    • Slide the second cover (yellow) to the right (similar to the outer cover). This will allow the batteries to be exposed.
    Ask FixBot
  3. Nikon Coolpix S30 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the batteries by gently tipping the camera.
    Ask FixBot
  4. Nikon Coolpix S30 LCD Screen Replacement, LCD Screen: step 4, image 1 of 1
    • FIRST: remove the batteries.
    • Unscrew the four screws around the corners of the camera. This can be done using the iFixit kit's T5 (star tip screwdriver)
    Ask FixBot
  5. Nikon Coolpix S30 LCD Screen Replacement: step 5, image 1 of 1
    • Unscrew the screw on the left (silver) first. It can be removed with the same tip (T5)
    • Change screwdriver tip to iFixit kit's PH000. This removes the screw on the right (black) It is a small Phillips head.
    Ask FixBot
  6. Nikon Coolpix S30 LCD Screen Replacement: step 6, image 1 of 1
    • Gently separate the back panel from the rest of the camera.
    Ask FixBot
  7. Nikon Coolpix S30 LCD Screen Replacement: step 7, image 1 of 1
    • Remove screw connecting the top right of the screen to the mother board.
    Ask FixBot
  8. Nikon Coolpix S30 LCD Screen Replacement: step 8, image 1 of 1
    • Spin the camera around and gently pull the screen towards you. This will allow easy access to components on the motherboard.
    Ask FixBot
  9. Nikon Coolpix S30 LCD Screen Replacement: step 9, image 1 of 2 Nikon Coolpix S30 LCD Screen Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Remove connected strip by flipping up the small off-white plastic strip with tweezers.
    • Gently pull out the strip from the motherboard.
    Ask FixBot
  10. Nikon Coolpix S30 LCD Screen Replacement: step 10, image 1 of 2 Nikon Coolpix S30 LCD Screen Replacement: step 10, image 2 of 2
    • Remove screw that is now in the top right corner. This will detach the screen entirely.
    Ask FixBot
Cassie Hamm
207 Reputation
2 Guides authored
Penn State, Team 2-4, Kaschak Winter 2015 Member of Penn State, Team 2-4, Kaschak Winter 2015
PSU-KASCHAK-W15S2G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 1,254
