This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Nikon Coolpix P7000 Disassembly
Views: 5.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
29
Past 30 Days:
135
All Time:
5,941
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows how to disassemble a Nikon Coolpix P7000 camera to access its motherboard, lens assembly, and other internal components. Lift the rear cover carefully: two ribbon cables connect it to the motherboard.
    1. Nikon Coolpix P7000 Disassembly, Remove the screws: step 1, image 1 of 3 Nikon Coolpix P7000 Disassembly, Remove the screws: step 1, image 2 of 3 Nikon Coolpix P7000 Disassembly, Remove the screws: step 1, image 3 of 3
      • Start by removing all the screws visible on the body of the device.
      Ask FixBot
    2. Nikon Coolpix P7000 Disassembly, Removal of the back of the device: step 2, image 1 of 3 Nikon Coolpix P7000 Disassembly, Removal of the back of the device: step 2, image 2 of 3 Nikon Coolpix P7000 Disassembly, Removal of the back of the device: step 2, image 3 of 3
      • Once all the screws are removed, gently lift the back of the device as it is connected to the motherboard by two ribbon cables.
      • Remove the screws and then, the metal protection plate.
      • Disconnect the ribbon cables from the motherboard by gently lifting the plastic valves.
      • Then, remove the mounting screws from the motherboard. Remove the motherboard but be careful, as it is still connected to the frame with the speaker wires.
      Ask FixBot
    3. Nikon Coolpix P7000 Disassembly, Removing the upper housing: step 3, image 1 of 3 Nikon Coolpix P7000 Disassembly, Removing the upper housing: step 3, image 2 of 3 Nikon Coolpix P7000 Disassembly, Removing the upper housing: step 3, image 3 of 3
      • Now, remove the top cover.
      • Remove the screw which still maintains the frame. You will find it behind this red circle.
      • All you have to do now is to remove the optical unit, it comes more easily when pulling it up.
      • Your device is disassembled with success and you now have access to all its components.
      Ask FixBot
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Hardy
178 Reputation
2 Guides authored
6 Guide Comments
Hardy:
Thanks very much for your hard work on this. I have a P7000 whose memory card slot isn’t recognizing cards. I can’t tell for sure, but it looks like the card slot is part of the battery housing. Would you be able to confirm this?
Thanks
David Greene - Reply Share
were you able to figure it out, i realized im also having the same problem
paper - Reply Share
Thank you!!! Is there a way to replace the internal battery? Is it present? My p7000 no longer keeps the date/time and settings memory whenever I remove the EN-EL14 battery...
Luca Salvatori - Reply Share
i Have the same issue, Did you fix yours? I think my the issue is related to the Lithium-ion flash capacitor.
But I'm struggling to find that specific part.
Miguel Marques - Reply Share
хорошая работа - поделиться с людьми информацией. здоровья и удачи мастеру .
Serg Ponomarenko - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 135
All Time: 5,941
