Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓This guide will provide instructions on replacing the LCD screen for the camera. This guide can be followed if the LCD screen has been cracked or broken.
Tools
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
Tool used on this step:Tweezers$4.99
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
2 other people completed this guide.
