Nikon Coolpix P530 Battery Replacement
Views: 5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
103
All Time:
4,995
Comments: 3
3 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
Continual usage can drain the Nikon Coolpix P530’s battery shortening its lifespan. This guide utilizes a step by step approach on changing the battery in your device. Before following this guide, ensure that the Nikon EN-EL5 rechargeable lithium-ion battery or suitable equivalent is being used during the replacement.
Parts
Tools
    1. Nikon Coolpix P530 Battery Replacement, Battery: step 1, image 1 of 1
      • Identify the battery chamber found at the bottom of the device.
      • Ensure the camera is turned off before conducting any maintenance on the device.
      Ask FixBot
    2. Nikon Coolpix P530 Battery Replacement: step 2, image 1 of 3 Nikon Coolpix P530 Battery Replacement: step 2, image 2 of 3 Nikon Coolpix P530 Battery Replacement: step 2, image 3 of 3
      • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
      • The spring loaded battery chamber door will swing open after the switch is moved.
      Ask FixBot
    3. Nikon Coolpix P530 Battery Replacement: step 3, image 1 of 3 Nikon Coolpix P530 Battery Replacement: step 3, image 2 of 3 Nikon Coolpix P530 Battery Replacement: step 3, image 3 of 3
      • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
      • After the yellow tab is depressed, the battery should partially eject from the camera.
      Ask FixBot
    4. Nikon Coolpix P530 Battery Replacement: step 4, image 1 of 2 Nikon Coolpix P530 Battery Replacement: step 4, image 2 of 2
      • Gently remove the battery from the chamber.
      Ask FixBot
3 other people completed this guide.
3 Guide Comments
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Reply Share
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Reply Share
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 103
All Time: 4,995
