Nikon Coolpix P510 Lens Assembly Replacement
Views: 5.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
109
All Time:
5,194
Comments: 3
3 comments on steps.
Completed: 9
9 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide takes a little time to get to the lens assembly. However, it is fairly easy and only requires vary minimal amount of tools to do so.
Tools
    1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: step 1, image 1 of 2 Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: step 1, image 2 of 2
      • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
      • On the thumb grip, remove the one 4mm PH00 Philips screw.
      Ask FixBot
    2. Nikon Coolpix P510 Lens Assembly Replacement: step 2, image 1 of 1
      • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
      • One of the screws are under the HDMI and A/V Out cover.
      Ask FixBot
    3. Nikon Coolpix P510 Lens Assembly Replacement: step 3, image 1 of 1
      • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
      Ask FixBot
    4. Nikon Coolpix P510 Lens Assembly Replacement: step 4, image 1 of 1
      • open the display and remove the two Ph 00 screws near the hinge
      Ask FixBot
    5. Nikon Coolpix P510 Lens Assembly Replacement: step 5, image 1 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 5, image 2 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 5, image 3 of 3
      • Open the flash and use a plastic opening tool to pop the tab under it as shown.
      • Now pull the casing apart.
      • The tripod attachment may fall out on its own, or you will need to pull it out.
      Ask FixBot
    6. Nikon Coolpix P510 Lens Assembly Replacement: step 6, image 1 of 2 Nikon Coolpix P510 Lens Assembly Replacement: step 6, image 2 of 2
      • Unplug the two ribbon cables to completely detach the back, by securely opening the latch
      Ask FixBot
    7. Nikon Coolpix P510 Lens Assembly Replacement: step 7, image 1 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 7, image 2 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 7, image 3 of 3
      • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
      • Remove one 5mm PH00 Philips screw
      • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
      • With all the screws out, the metal plate should simply lift off.
      Ask FixBot
    8. Nikon Coolpix P510 Lens Assembly Replacement: step 8, image 1 of 2 Nikon Coolpix P510 Lens Assembly Replacement: step 8, image 2 of 2
      • With the metal plate off, unplug this ribbon cable from the motherboard.
      • To remove the flat-topped connector, you simply lift it up to unplug it.
      Ask FixBot
    9. Nikon Coolpix P510 Lens Assembly Replacement: step 9, image 1 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 9, image 2 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 9, image 3 of 3
      • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
      Ask FixBot
    10. Nikon Coolpix P510 Lens Assembly Replacement: step 10, image 1 of 2 Nikon Coolpix P510 Lens Assembly Replacement: step 10, image 2 of 2
      • With the support screws out, you can simply slide the assembly out of the casing.
      Ask FixBot
    11. Nikon Coolpix P510 Lens Assembly Replacement: step 11, image 1 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 11, image 2 of 3 Nikon Coolpix P510 Lens Assembly Replacement: step 11, image 3 of 3
      • If you are moving on to take the lens casing off, you do not need to do this step.
      • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
      Ask FixBot
9 other people completed this guide.
Brian Hulsey
1,554 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 109
All Time: 5,194
