Nikon Coolpix P510 Battery Removal Replacement
    1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: step 1, image 1 of 1
      • Flip the camera over and push the tab on the battery cover to open the battery compartment.
      Ask FixBot
    2. Nikon Coolpix P510 Battery Removal Replacement: step 2, image 1 of 2 Nikon Coolpix P510 Battery Removal Replacement: step 2, image 2 of 2
      • Push the little yellow tab to allow the battery to slide out.
      • With the tab pushed out, pull the battery out.
      Ask FixBot
Brian Hulsey
1,554 Reputation
6 Guides authored
3 Guide Comments
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Reply Share
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Reply Share
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 62
All Time: 5,118
