Nikon Coolpix P100 Back Buttons Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
89
All Time:
1,394
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
If you have a jammed button or if you simply want to replace a part on your Nikon Coolpix P100 camera, then this guide is perfect for you! This guide will help users easily replace a broken back button on your Nikon Coolpix P100 camera.The only required tools you need are a Phillips #00 Screwdriver and a iFixit Opening Tool.
Before using this guide make sure that the camera is powered off!
Tools
    1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: step 1, image 1 of 1
      • Turn the front of the camera toward you.
      Ask FixBot
    2. Nikon Coolpix P100 Back Buttons Replacement: step 2, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 2, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 2, image 3 of 3
      • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Nikon Coolpix P100 Back Buttons Replacement: step 3, image 1 of 1
      • On the right side of the camera, remove the first visible screw.
      Ask FixBot
    4. Nikon Coolpix P100 Back Buttons Replacement: step 4, image 1 of 1
      • Lift the HDMI and A/V OUT cover to access the hidden screw.
      Ask FixBot
    5. Nikon Coolpix P100 Back Buttons Replacement: step 5, image 1 of 1
      • Flip the camera upside down and remove the seven marked screws.
      Ask FixBot
    6. Nikon Coolpix P100 Back Buttons Replacement: step 6, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 6, image 2 of 2
      • Remove the two screws hidden underneath the display panel.
      Ask FixBot
    7. Nikon Coolpix P100 Back Buttons Replacement: step 7, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 7, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 7, image 3 of 3
      • Use a plastic opening tool to gently loosen up the sides of the camera.
      Ask FixBot
    8. Nikon Coolpix P100 Back Buttons Replacement: step 8, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 8, image 2 of 2
      • Carefully open the camera.
      • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
      Ask FixBot
    9. Nikon Coolpix P100 Back Buttons Replacement: step 9, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 9, image 2 of 2
      • This is the cover that houses the back buttons of the camera. Turn it around.
      Ask FixBot
    10. Nikon Coolpix P100 Back Buttons Replacement: step 10, image 1 of 1
      • Remove the six indicated screws.
      Ask FixBot
    11. Nikon Coolpix P100 Back Buttons Replacement: step 11, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 11, image 2 of 2
      • Use a plastic opening tool to lift the metal plate and set it aside.
      Ask FixBot
    12. Nikon Coolpix P100 Back Buttons Replacement: step 12, image 1 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 12, image 2 of 3 Nikon Coolpix P100 Back Buttons Replacement: step 12, image 3 of 3
      • Turn the cover around and push against the buttons.
      Ask FixBot
    13. Nikon Coolpix P100 Back Buttons Replacement: step 13, image 1 of 1
      • Now you have partial access to one set of buttons.
      Ask FixBot
    14. Nikon Coolpix P100 Back Buttons Replacement: step 14, image 1 of 1
      • Find the last set of removal buttons on the bottom left.
      Ask FixBot
    15. Nikon Coolpix P100 Back Buttons Replacement: step 15, image 1 of 1
      • Remove the screw.
      Ask FixBot
    16. Nikon Coolpix P100 Back Buttons Replacement: step 16, image 1 of 2 Nikon Coolpix P100 Back Buttons Replacement: step 16, image 2 of 2
      • Use a plastic opening tool to remove the button.
      Ask FixBot
Nghiem Ngo
339 Reputation
2 Guides authored
USF Tampa, Team 1-1, Tanski Winter 2015 Member of USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 89
All Time: 1,394
