Nikon Coolpix L830 LCD Monitor Replacement
  1. Nikon Coolpix L830 LCD Monitor Replacement, LCD Monitor: step 1, image 1 of 1
    • Use a Phillips head P000 screwdriver to remove the four 3.0 mm Phillips screws on the back of the monitor.
    Ask FixBot
  2. Nikon Coolpix L830 LCD Monitor Replacement: step 2, image 1 of 1
    • Use a Phillips head P000 screwdriver to remove the two 3.0 mm Phillips screws on the hinge cover.
    Ask FixBot
  3. Nikon Coolpix L830 LCD Monitor Replacement: step 3, image 1 of 2 Nikon Coolpix L830 LCD Monitor Replacement: step 3, image 2 of 2
    • Remove the top hinge cover.
    • The top hinge cover contains screw holes.
    • Remove the bottom hinge cover.
    • The bottom hinge cover contains no screw holes.
    Ask FixBot
  4. Nikon Coolpix L830 LCD Monitor Replacement: step 4, image 1 of 1
    • Remove the back cover of the LCD monitor with your hands or a plastic opening tool.
    • The cover will slide down the hinge, but it will not be completely removed.
    Ask FixBot
  5. Nikon Coolpix L830 LCD Monitor Replacement: step 5, image 1 of 2 Nikon Coolpix L830 LCD Monitor Replacement: step 5, image 2 of 2
    • Use your thumb to gently pull the small flex ribbon wire connector from its socket.
    • Use your thumb to gently pull the wide flex ribbon wire connector from its socket.
    Ask FixBot
  6. Nikon Coolpix L830 LCD Monitor Replacement: step 6, image 1 of 1
    • Use a plastic opening tool to remove the front cover of the LCD monitor, allowing the monitor to be completely be released.
    Ask FixBot
  7. Nikon Coolpix L830 LCD Monitor Replacement: step 7, image 1 of 1
    • Gently remove the old, damaged LCD monitor.
    Ask FixBot
Blake Johnson
359 Reputation
2 Guides authored
Baylor, Team 4-4, Williams Fall 2016 Member of Baylor, Team 4-4, Williams Fall 2016
BU-WILLIAMS-F16S4G4
3 Members
10 Guides authored
2 Guide Comments
I cant remove two of the screws. Help
jo Hogan - Reply Share
Très bien pour démonter , mais pour remonter les nappes, notamment la moins large, je n'arrive pas à l'insérer !
Avez vous une technique à me proposer ?
Michel Cassel - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 44
All Time: 3,378
