Nikon Coolpix L810 LCD Replacement
    1. Nikon Coolpix L810 LCD Replacement, LCD: step 1, image 1 of 2 Nikon Coolpix L810 LCD Replacement, LCD: step 1, image 2 of 2
      Tool used on this step:
      Buy
      • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
      • Use of precision tweezers to help remove loosened screws is suggested.
      Ask FixBot
    2. Nikon Coolpix L810 LCD Replacement: step 2, image 1 of 2 Nikon Coolpix L810 LCD Replacement: step 2, image 2 of 2
      • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
      Ask FixBot
    3. Nikon Coolpix L810 LCD Replacement: step 3, image 1 of 2 Nikon Coolpix L810 LCD Replacement: step 3, image 2 of 2
      • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
      Ask FixBot
    4. Nikon Coolpix L810 LCD Replacement: step 4, image 1 of 1
      • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
      Ask FixBot
    5. Nikon Coolpix L810 LCD Replacement: step 5, image 1 of 2 Nikon Coolpix L810 LCD Replacement: step 5, image 2 of 2
      • With the LCD screen facing towards you, flip the screen to the right.
      Ask FixBot
    6. Nikon Coolpix L810 LCD Replacement: step 6, image 1 of 3 Nikon Coolpix L810 LCD Replacement: step 6, image 2 of 3 Nikon Coolpix L810 LCD Replacement: step 6, image 3 of 3
      • Remove three 5 mm Phillips #000 screws located on the bracket.
      • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
      Ask FixBot
    7. Nikon Coolpix L810 LCD Replacement: step 7, image 1 of 2 Nikon Coolpix L810 LCD Replacement: step 7, image 2 of 2
      • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
      Ask FixBot
4 other people completed this guide.
Emilio Mena
800 Reputation
4 Guides authored
UW Tacoma, Team 3-1, Rose Winter 2015 Member of UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Members
48 Guides authored
2 Guide Comments
I love ifixit instructions so much more than youtube. These are so easy and straightfoward and I love how screw sizes are carefully specified.
Susan - Reply Share
Congratulations! Perfect lesson !
I need HELP presentation abowt desassembler / remove motherboard and other parts to repair the lenz move mechanism. Unfortunately NIKON left Brazil and the resident Suport tecnician besides not being good, stay in quarentine (corona virus)! Special Thanks for you help! Best regards
ramos.eng - Reply Share
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 56
All Time: 3,532
